How to link fpsdisplaysink and fakesink in C-code
I can run the follow command well by using terminal:gst-launch-1.0 -v nvarguscamerasrc sensor-id=1 ! ‘video/x-raw(memory:NVMM),width=4000,height=3000,framerate=25/1’ ! tee name=t ! queue ! fpsdisplaysink text-overlay=0 video-sink=fakesink sync=0 t. ! queue ! fpsdisplaysink text-overlay=0 video-sink=fakesink sync=0 t. ! queue ! fpsdisplaysink text-overlay=0 video-sink=fakesink sync=0 t. ! queue ! fpsdisplaysink text-overlay=0 video-sink=fakesink sync=0
It run well and the pipeline is as the follow figure :
But after I build and run the pipeline by using C-codem,the fakesink was change to autovideosink,but I didn’t create this plug-in(autovideosink) in the code,Is there something bug with my code?
verify_version.tar (820 KB)
Please check if this sample helps:
frame rate - Display FPS in Gstreamer's C source - Stack Overflow
Hello,DaneLL
It is a problem when using fakesink with fpsdisplaysink.
I used appsink instead of fpsdisplaysink to complete the verification.
