How to load a model into graph composer?
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 7.0
• TensorRT Version 8.5
• Issue Type( questions, new requirements, bugs) question
I have trained a resnet on my data and have a .pb file with its weights. I want to know if there is a way to use that model on graph composer in the same way I can use the sample models used on deepstream tests 1 and 2. I know that I probably have to convert it to onnx format.
I’ve already seen similar questions on this forum but I still don’t have any idea of how I can do that. Most of them were referring to the peoplenet TAO model or something similar.
The onnx model can be supported.
What files do I have to export and where?What do I have to do in order to see the new model in graph composer just like I can see the sample models?I want to see my trained model in there.
You can use the NvDsInferVideo extension. NvDsInferenceExt — DeepStream documentation 6.4 documentation
Set the correct nvinfer configuration file in the red circle.
