How to make code changes to gst-nvinfer and include the changes in deepstream-app
i have made few changes to gst-nvinfer i want to see that reflect on deepstream-app, how do i do it?
one suggestion: enable gie section property in configuration you used, add logs for your changes, based on the log levels, run deepstream-app with log enabled, like this:
GST_DEBUG=nvinfer:6 deepstream-app -c “config used”
check the log if have your added logs.
Hi amy, thanks for the reply.
I figured it, just had to replace .so files in lib/gst-plugins with the .so generated after make
