How to make Deepstream send a single json message for a single frame with multiple objects?
I’m playing with deepstream-test5 with kafka, and I found that if there are three objects in a single frame, DS will send 3 individual json for each object. How can I make DS to send only one single json message for a frame with multiple objects in it? Which code should I modify?
Thanks very much for any advice.
You would need to customize gst-nvmsgconv and gst-msgbroker. Please check the development guide and the source code in
deepstream_sdk_v4.0.2_jetson\sources\gst-plugins
