How to make gnc continuously available?
• Hardware (T4/V100/Xavier/Nano/etc) T4
• Network Type Faster_rcnn,Mask_rcnn
(Detectnet_v2/Faster_rcnn/Yolo_v4/LPRnet/Mask_rcnn/Classification/etc)
• TLT Version (Please run “tlt info --verbose” and share “docker_tag” here)
• Training spec file(If have, please share here) Tao 2,.0m toolkit_versiuon3.22.5
• How to reproduce the issue ? (This is for errors. Please share the command line and the detailed log here.)
Hello professor:
I am just starting to learn TAO toolkit. I meet a problem about GNC.
I create a conda environment, and follow the “About NGC CLI“ to down load the ngc. :NVIDIA NGC.
till to “ngc config set”. Then I can use the command ngc.
However, if I open a second terminal, and active the conda environment, but I can not use the ngc command. I need to download the ngc again.
So I hope to know, how to config the ngc, that I can use the command if I open another terminal with the same conda environment.
Thank you very much.
Where is your ngc?
$ which ngc
And, could you run “ngc config set” before you active conda environment?
Thank you very much for your response. If I use “which ngc”, there is nothing,
If command “ngc config set”, the command ‘ngc’ not found, did you mean:
command ‘gc’ from snap genesyscloud-cli(0.2)
Thank you very much
So, did you ever download ngc in your machine?
From NVIDIA NGC
wget --content-disposition https://ngc.nvidia.com/downloads/ngccli_linux.zip && unzip ngccli_linux.zip && chmod u+x ngc-cli/ngc
Yes I download the NGC as the follows
and I can login
But if I use the NGC code, I get as below
And if I use it in jupyter, the same
Please try
! /ngc-cli/ngc registry model list nvidia/tao/pretrained_object_detection:*
Thank you very much. But I got:
Try:
! ngc-cli/ngc registry model list nvidia/tao/pretrained_object_detection:*
When I try it in terminal, I got the right answer as below
However, when I run in Jupyter, I got
Please check and run below in notebook.
! pwd
! wget --content-disposition https://ngc.nvidia.com/downloads/ngccli_linux.zip && unzip ngccli_linux.zip && chmod u+x ngc-cli/ngc
I run !pwd before the other code, and I can get
Then, I added “ngc-cli/” before the command as you gave to me. and it succeed
My question is: Should I add the ! pwd and “ngc-cli/” before the command.
Yes, you can.
Thank you very much! it works
