Hi.
I want to make incoming traffic go outside without DMA in ConnectX-6 using eSwitch.
Is there any example code or guide for this use case?
What I found from DPDK document is only RSSing or dropping incoming packets.
I checked that RSSing and dropping work correctly.
However, there is no guide related to steering incoming flow to outside without DMA.
Hi @cerotyki ,
Hairpin can match your request.
https://patches.dpdk.org/project/dpdk/patch/1565703468-55617-1-git-send-email-orika@mellanox.com/
https://doc.dpdk.org/api/structrte__eth__hairpin__conf.html
In general, the flow should be:
- packets received
- do MAC modifications with Flows
- send pkts to hairpin
- hairpin forwards packet to Tx
- packet is sent to wire
In dpdk version 22.03 there is an option to use internal NIC memory for hairpin.
Regards,
Chen
