How to make normally boot again with my jetson nano adapter
I have done my flashing , and use the sdk manager to install the jetpak now i got a new problem that when i power off it , it is not turning on , but it is working normal after the flash when i connect to adapter of my nano it is not turning on and it just stay blank and the red light is alone is on
You mean you jetson Nano doesn’t turn on if you power up by power adapter? I presume you have Jetson Nano development board with barrel connector on the left hand side corner? Check the jumper position as the picture shows: (Power Jack/USB power select jumper) https://global.discourse-cdn.com/nvidia/original/3X/7/8/787490861ef6850d88bc66323867e4b180f6930a.png
To avoid confusion, there is another topic here from varuns20.
Looks like the flash didn’t pass at all.
Please do not take sdcard image as “flash”. It didn’t flash anything to the board.
