wilicyy
November 18, 2021, 11:25am
1
hi,
before i used tensorrt_demos project to change onnx model to int8 model file,
tensorrt version is 7.1.3 and jetpack is 4.5.1.
yesterday i update new jetpack to 4.6 version and Tensorrt is 8.0.
in tensorrt_demos plugins’ make file:
These are the directories where I installed TensorRT on my x86_64 PC.
TENSORRT_INCS=-I"/usr/local/TensorRT-7.1.3.4/include"
TENSORRT_LIBS=-L"/usr/local/TensorRT-7.1.3.4/lib"
at jetpack 4.6 version, i didn’t fine TensorRT in /usr/local/,
so how can i do now? how to make plugins?
thank you very much!
You can find the TensorRT include patch in /usr/include/aarch64-linux-gnu/
and library path in usr/lib/aarch64-linux-gnu/
$ ll /usr/lib/aarch64-linux-gnu/libnvinfer*
lrwxrwxrwx 1 root root 26 Jun 25 20:17 /usr/lib/aarch64-linux-gnu/libnvinfer_plugin.so -> libnvinfer_plugin.so.8.0.1
lrwxrwxrwx 1 root root 26 Jun 25 20:17 /usr/lib/aarch64-linux-gnu/libnvinfer_plugin.so.8 -> libnvinfer_plugin.so.8.0.1
-rw-r--r-- 1 root root 18280576 Jun 25 20:17 /usr/lib/aarch64-linux-gnu/libnvinfer_plugin.so.8.0.1
-rw-r--r-- 1 root root 21018654 Jun 25 20:17 /usr/lib/aarch64-linux-gnu/libnvinfer_plugin_static.a
lrwxrwxrwx 1 root root 19 Jun 25 20:17 /usr/lib/aarch64-linux-gnu/libnvinfer.so -> libnvinfer.so.8.0.1
lrwxrwxrwx 1 root root 19 Jun 25 20:17 /usr/lib/aarch64-linux-gnu/libnvinfer.so.8 -> libnvinfer.so.8.0.1
-rw-r--r-- 1 root root 188463744 Jun 25 20:17 /usr/lib/aarch64-linux-gnu/libnvinfer.so.8.0.1
-rw-r--r-- 1 root root 333591900 Jun 25 20:17 /usr/lib/aarch64-linux-gnu/libnvinfer_static.a
$ ll /usr/include/aarch64-linux-gnu/NvInfer*
-rw-r--r-- 1 root root 268726 Jun 25 20:17 /usr/include/aarch64-linux-gnu/NvInfer.h
-rw-r--r-- 1 root root 42497 Jun 25 20:17 /usr/include/aarch64-linux-gnu/NvInferImpl.h
-rw-r--r-- 1 root root 6176 Jun 25 20:17 /usr/include/aarch64-linux-gnu/NvInferLegacyDims.h
-rw-r--r-- 1 root root 11327 Jun 25 20:17 /usr/include/aarch64-linux-gnu/NvInferPlugin.h
-rw-r--r-- 1 root root 11819 Jun 25 20:17 /usr/include/aarch64-linux-gnu/NvInferPluginUtils.h
-rw-r--r-- 1 root root 60163 Jun 25 20:17 /usr/include/aarch64-linux-gnu/NvInferRuntimeCommon.h
-rw-r--r-- 1 root root 94791 Jun 25 20:17 /usr/include/aarch64-linux-gnu/NvInferRuntime.h
-rw-r--r-- 1 root root 3148 Jun 25 20:17 /usr/include/aarch64-linux-gnu/NvInferVersion.h
wilicyy
November 19, 2021, 4:14am
5
i make successfully as your instruction, but it shows: - virtual function override intended?
can it work correctly?
thank you!
This is a harmless warning. It can run correctly.
wilicyy
November 25, 2021, 1:02pm
7
yes it runs but speed is a little slower.
i setup mvpmodel as -m 2 because in documents:
Quickstart Guide — DeepStream 6.1.1 Release documentation , it suggests:
For Jetson Xavier NX, run sudo nvpmodel -m 2 instead of 0.
but int8 model is a little slower than before, i compared.
thank you.
Would you mind opening a new topic for the performance issue?
system
Closed
December 22, 2021, 5:44am
10
