Hi:
I want to make spi(pins G13 F13 F14 E14) works on Jetson TX1 during uboot, How can i do to accomplish it?
thanks!
Hi:
thanks!
Have a reference to below link
Hello:
I want to add the SPI driver to uboot, and configure the pins in u-boot\board\nvidia\p2371-2180\pinmux-config-p2371-2180.h, as follows:
static const struct tegra_gpio_config p2371_2180_gpio_inits[] = {
/* port, pin, init_val */
GPIO_INIT(A, 5, IN),
GPIO_INIT(B, 0, IN),
GPIO_INIT(B, 1, IN),
GPIO_INIT(B, 2, IN),
GPIO_INIT(B, 3, IN),
GPIO_INIT(E, 4, IN),
GPIO_INIT(E, 5, IN),
GPIO_INIT(E, 6, IN),
GPIO_INIT(H, 0, OUT0),
GPIO_INIT(H, 1, OUT0),
GPIO_INIT(H, 2, IN),
GPIO_INIT(H, 3, OUT0),
GPIO_INIT(H, 4, OUT0),
GPIO_INIT(H, 5, IN),
GPIO_INIT(H, 6, IN),
GPIO_INIT(H, 7, IN),
GPIO_INIT(I, 0, OUT0),
GPIO_INIT(I, 1, IN),
GPIO_INIT(I, 2, OUT0),
GPIO_INIT(K, 4, IN),
GPIO_INIT(K, 5, OUT0),
GPIO_INIT(K, 6, IN),
GPIO_INIT(K, 7, IN),
GPIO_INIT(L, 1, IN),
GPIO_INIT(S, 4, OUT0),
GPIO_INIT(S, 5, OUT0),
GPIO_INIT(S, 6, OUT0),
GPIO_INIT(S, 7, OUT0),
GPIO_INIT(T, 0, OUT0),
GPIO_INIT(T, 1, OUT0),
GPIO_INIT(U, 2, IN),
GPIO_INIT(U, 3, IN),
GPIO_INIT(V, 1, OUT0),
GPIO_INIT(V, 2, OUT0),
GPIO_INIT(V, 3, IN),
GPIO_INIT(V, 5, OUT0),
GPIO_INIT(V, 6, OUT0),
GPIO_INIT(X, 0, IN),
GPIO_INIT(X, 1, IN),
GPIO_INIT(X, 2, IN),
GPIO_INIT(X, 3, IN),
GPIO_INIT(X, 4, IN),
GPIO_INIT(X, 5, IN),
GPIO_INIT(X, 6, IN),
GPIO_INIT(X, 7, IN),
GPIO_INIT(Y, 0, IN),
GPIO_INIT(Y, 1, IN),
GPIO_INIT(Z, 0, IN),
GPIO_INIT(Z, 2, IN),
GPIO_INIT(Z, 3, OUT0),
GPIO_INIT(BB, 0, IN),
GPIO_INIT(BB, 2, OUT0),
GPIO_INIT(BB, 3, IN),
GPIO_INIT(CC, 1, IN),
static const struct pmux_pingrp_config p2371_2180_pingrps[] = {
/* pingrp, mux, pull, tri, e_input, od, e_io_hv */
PINCFG(PEX_L0_RST_N_PA0, PE0, NORMAL, NORMAL, OUTPUT, DISABLE, HIGH),
PINCFG(PEX_L0_CLKREQ_N_PA1, PE0, NORMAL, NORMAL, INPUT, DISABLE, HIGH),
PINCFG(PEX_WAKE_N_PA2, PE, NORMAL, NORMAL, INPUT, DISABLE, HIGH),
PINCFG(PEX_L1_RST_N_PA3, PE1, NORMAL, NORMAL, OUTPUT, DISABLE, HIGH),
PINCFG(PEX_L1_CLKREQ_N_PA4, PE1, NORMAL, NORMAL, INPUT, DISABLE, HIGH),
PINCFG(SATA_LED_ACTIVE_PA5, DEFAULT, UP, NORMAL, INPUT, DISABLE, DEFAULT),
PINCFG(PA6, SATA, NORMAL, NORMAL, OUTPUT, DISABLE, DEFAULT),
PINCFG(DAP1_FS_PB0, DEFAULT, DOWN, NORMAL, INPUT, DISABLE, DEFAULT),
PINCFG(DAP1_DIN_PB1, DEFAULT, DOWN, NORMAL, INPUT, DISABLE, DEFAULT),
PINCFG(DAP1_DOUT_PB2, DEFAULT, DOWN, NORMAL, INPUT, DISABLE, DEFAULT),
PINCFG(DAP1_SCLK_PB3, DEFAULT, DOWN, NORMAL, INPUT, DISABLE, DEFAULT),
PINCFG(SPI2_MOSI_PB4, SPI2, DOWN, NORMAL, OUTPUT, DISABLE, DEFAULT),
PINCFG(SPI2_MISO_PB5, SPI2, DOWN, NORMAL, INPUT, DISABLE, DEFAULT),
PINCFG(SPI2_SCK_PB6, SPI2, DOWN, NORMAL, OUTPUT, DISABLE, DEFAULT),
PINCFG(SPI2_CS0_PB7, SPI2, UP, NORMAL, OUTPUT, DISABLE, DEFAULT),
PINCFG(SPI2_CS1_PDD0, SPI2, UP, NORMAL, OUTPUT, DISABLE, DEFAULT),
PINCFG(SPI1_MOSI_PC0, SPI1, DOWN, NORMAL, INPUT, DISABLE, DEFAULT),
PINCFG(SPI1_MISO_PC1, SPI1, DOWN, NORMAL, INPUT, DISABLE, DEFAULT),
PINCFG(SPI1_SCK_PC2, SPI1, DOWN, NORMAL, INPUT, DISABLE, DEFAULT),
PINCFG(SPI1_CS0_PC3, SPI1, UP, NORMAL, INPUT, DISABLE, DEFAULT),
PINCFG(SPI1_CS1_PC4, SPI1, UP, NORMAL, INPUT, DISABLE, DEFAULT),
PINCFG(SPI4_SCK_PC5, SPI4, DOWN, NORMAL, INPUT, DISABLE, DEFAULT),
PINCFG(SPI4_CS0_PC6, SPI4, UP, NORMAL, INPUT, DISABLE, DEFAULT),
PINCFG(SPI4_MOSI_PC7, SPI4, DOWN, NORMAL, INPUT, DISABLE, DEFAULT),
PINCFG(SPI4_MISO_PD0, SPI4, DOWN, NORMAL, INPUT, DISABLE, DEFAULT),
PINCFG(UART3_TX_PD1, UARTC, NORMAL, NORMAL, OUTPUT, DISABLE, DEFAULT),
PINCFG(UART3_RX_PD2, UARTC, UP, NORMAL, INPUT, DISABLE, DEFAULT),
PINCFG(UART3_RTS_PD3, UARTC, NORMAL, NORMAL, OUTPUT, DISABLE, DEFAULT),
PINCFG(UART3_CTS_PD4, UARTC, UP, NORMAL, INPUT, DISABLE, DEFAULT),
PINCFG(DMIC1_CLK_PE0, I2S3, NORMAL, NORMAL, INPUT, DISABLE, DEFAULT),
PINCFG(DMIC1_DAT_PE1, I2S3, NORMAL, NORMAL, INPUT, DISABLE, DEFAULT),
I am using SPI2. After running the driver, the SPI will not work. Is the pin multiplexing configuration correct? If not, how to configure it? thank you!
Could you try SPI1 first?
I am a bit uncertain about the address mapping relationship of SPI. The pin in “Jetson_TX1_Generic_Customer_Pinmux_Customer_Release.xlsm” is defined as follows:
Jetson TX1 Pin Name Jetson TX1 Pin # Ball Name Unused GPIO SFIO0
SPI
SPI0_MOSI F4 SPI4_MOSI unused_SPI4_MOSI SPI4A_DOUT
SPI0_MISO E4 SPI4_MISO unused_SPI4_MISO SPI4A_DIN
SPI0_CLK E3 SPI4_SCK unused_SPI4_SCK SPI4A_SCK
SPI0_CS0# F3 SPI4_CS0 unused_SPI4_CS0 SPI4A_CS0
SPI1_MOSI F13 SPI1_MOSI unused_SPI1_MOSI GPIO3_PC.00 SPI1A_DOUT
SPI1_MISO F14 SPI1_MISO unused_SPI1_MISO GPIO3_PC.01 SPI1A_DIN
SPI1_CLK G13 SPI1_SCK unused_SPI1_SCK GPIO3_PC.02 SPI1A_SCK
SPI1_CS0# E14 SPI1_CS0 unused_SPI1_CS0 GPIO3_PC.03 SPI1A_CS0
SPI1_CS1# E13 SPI1_CS1 unused_SPI1_CS1 GPIO3_PC.04 SPI1A_CS1
SPI2_MOSI G15 SPI2_MOSI unused_SPI2_MOSI SPI2A_DOUT
SPI2_MISO H15 SPI2_MISO unused_SPI2_MISO SPI2A_DIN
SPI2_CLK H14 SPI2_SCK unused_SPI2_SCK SPI2A_SCK
SPI2_CS0# G16 SPI2_CS0 unused_SPI2_CS0 SPI2A_CS0
SPI2_CS1# F16 SPI2_CS1 unused_SPI2_CS1 SPI2A_CS1
The address mapping relationship on page 21 in “Tegra_X1_TRM_DP07225001_v1.2p.pdf” is as follows:
SPI 2B-1 7000:d400 7000:d5ff 0000:d400 0000:d5ff 512 B
SPI 2B-2 7000:d600 7000:d7ff 0000:d600 0000:d7ff 512 B
SPI 2B-3 7000:d800 7000:d9ff 0000:d800 0000:d9ff 512 B
SPI 2B-4 7000:da00 7000:dbff 0000:da00 0000:dbff 512 B
I think SPI1’s address mapping is 0x7000d400, SPI2 address mapping is 0x7000d600, SPI4 address mapping is 0x7000da00, is this correct?
According to the above address mapping, SPI1 and SPI4 can work, but SPI2 can not work, SPI2 chip select is valid, how can we make SPI2 work? The following is the pin multiplexing of SPI2,thank you!
PINCFG(SPI2_MOSI_PB4, SPI2, DOWN, NORMAL, INPUT, DISABLE, DEFAULT),
PINCFG(SPI2_SCK_PB6, SPI2, DOWN, NORMAL, INPUT, DISABLE, DEFAULT),
PINCFG(SPI2_CS0_PB7, SPI2, UP, NORMAL, INPUT, DISABLE, DEFAULT),
PINCFG(SPI2_CS1_PDD0, SPI2, UP, NORMAL, INPUT, DISABLE, DEFAULT),
Hi:
After running the driver for different SPIs, I can measure the SCLK signals of SPI1 (0x7000d400) and SPI4 (0x7000da00), but I can’t measure the SCLK signal of SPI2 (0x7000d600). I compared the dts and Pinmux Registers, I found no difference. What else needs to be done to get SPI2 working properly? Thank you!
