• Hardware Platform (Jetson / GPU) dGPU • DeepStream Version 6.1Docker container • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
I’ve learned from source/lib/nvmsgbroker/readme file that user can override the default properties in nvmsgbroker lib by change values in “cfg_nvmsgbroker.txt”, which is exactly what I want to do. But I cannot find any relevant information about where this config file should be placed and how I can config the path in which deepstream-app’s config files. I only found a similar post: How to test nv_msgbroker autoreconnect feature but no one answered his question about the location of the file.
please refer to “#msg-broker-config=/opt/nvidia/deepstream/deepstream/sources/libs/kafka_protocol_adaptor/cfg_kafka.txt” in \opt\nvidia\deepstream\deepstream\sources\apps\sample_apps\deepstream-test5\configs\test5_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt
I’ve check the config file “cfg_kafka.txt”. It has one [message-broker] group and several items in it as follows: [message-broker] #consumer-group-id = #proto-cfg = “<semicolon separated key=value pairs generic for both producer & consumer>” #producer-proto-cfg = “” #consumer-proto-cfg = “” #partition-key = #share-connection = 1
I cannot figure out which item corresponding to “cfg-nvmsgbroker.txt”. BTW, I’ve used AMQP adapter a lot which has following configs (cfg_amqp.txt):
please refer to “Configuration” part in opt\nvidia\deepstream\deepstream\sources\libs\nvmsgbroker\README. there are many kinds of broker, such as kafka, AMQP, you can overwrite cfg_nvmsgbroker.txt with adding the specific configurations for AMQP.
Thank you for the reply. I just want to make it clearer if this is what your meaning:
In application config file, just setup the path of the nvmsgbroker’s config file. In the nvmsgbroker config file, first part you can begin with [nvmsgbroker] group:
