Hi, previously, there was a bug which cause the stopping criterion not to work.
It has now been fixed, as given in https://forums.developer.nvidia.com/t/problem-with-using-criterion-based-stopping/233377
However, I found that using the stopping criterion cause Modulus to stop rather early. I need to compute and compare the wall shear stress with my OpenFOAM results. Hence, in Modulus, I’ll be computing du/dy (u__y) etc. To get accurate result, I need to run about 600,000 to 800,000 steps.
My stopping criterion are:
stop_criterion:
metric: ‘l2_relative_error_u’
min_delta: 0.1
patience: 10000
mode: ‘min’
freq: 2000
strict: true
I found that even if I reduce min_delta to 1e-5, Modulus stops at around 80,0000. If I resume running, it goes for another 10,000 steps due to the patience parameters. But my wall shear stress results are still far from the ideal result. How should I tune to ensure that it will run till I reach my satisfied accurate wall shear stress?
