These are dmesg information:
xxx@awaicamera:~$ dmesg
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Linux version 4.9.201-tegra (buildbrain@mobile-u64-5285-d7000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Fri Feb 19 08:42:04 PST 2021
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 80,
[ 0.000000] OF: fdt: - 80000000 , 70000000
[ 0.000000] OF: fdt: - f0200000 , 145600000
[ 0.000000] OF: fdt: - 235e00000 , 200000
[ 0.000000] OF: fdt: - 236600000 , 200000
[ 0.000000] OF: fdt: - 237000000 , 200000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000003100000 (options ‘’)
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] Found tegra_fbmem2: 00800000@96081000
[ 0.000000] Found lut_mem2: 00002008@9607e000
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb0_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb2_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[ 0.000000] On node 0 totalpages: 1790973
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 521725 pages, LIFO batch:31
[ 0.000000] Normal zone: 19912 pages used for memmap
[ 0.000000] Normal zone: 1269248 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 24 pages/cpu s57560 r8192 d32552 u98304
[ 0.000000] pcpu-alloc: s57560 r8192 d32552 u98304 alloc=24*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1762869
[ 0.000000] Kernel command line: console=ttyS0,115200 androidboot.presilicon=true firmware_class.path=/etc/firmware root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 isolcpus=1-2 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x2372e0000 gpt rootfs.slot_suffix= tegra_fbmem2=0x800000@0x96081000 lut_mem2=0x2008@0x9607e000 usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2031647.1 vpr_resize bl_prof_dataptr=0x10000@0x235840000 sdhci_tegra.en_boot_part_access=1 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 isolcpus=1-2
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29184(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 6237452K/7163892K available (15294K kernel code, 2942K rwdata, 6664K rodata, 8576K init, 609K bss, 172776K reserved, 753664K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f70000 ( 15296 KB)
[ 0.000000] .rodata : 0xffffff8008f70000 - 0xffffff8009600000 ( 6720 KB)
[ 0.000000] .init : 0xffffff8009600000 - 0xffffff8009e60000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e60000 - 0xffffff800a13f808 ( 2943 KB)
[ 0.000000] .bss : 0xffffff800a13f808 - 0xffffff800a1d7cbc ( 610 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf06dc8000 ( 109 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc1b7200000 ( 7026 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.001580] Console: colour dummy device 80x25
[ 0.001585] console [tty0] enabled
[ 0.001589] bootconsole [uart8250] disabled
[ 0.001596] kmemleak: Kernel memory leak detector disabled
[ 0.001606] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.001614] pid_max: default: 32768 minimum: 301
[ 0.001925] Security Framework initialized
[ 0.002079] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.002083] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.002690] ftrace: allocating 47208 entries in 185 pages
[ 0.128145] sched-energy: Sched-energy-costs installed from DT
[ 0.128156] ASID allocator initialised with 65536 entries
[ 0.164420] tegra-id: chipid=21817.
[ 0.164426] tegra-id: opt_subrevision=1.
[ 0.164441] Tegra Revision: A02p SKU: 0x90 CPU Process: 0 SoC Process: 0
[ 0.164449] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3489-1000-a00-00-base.dts
[ 0.164455] DTB Build time:
[ 0.213755] CPU1: Booted secondary processor [4e0f0030]
[ 0.245351] CPU2: Booted secondary processor [4e0f0030]
[ 0.277147] CPU3: Booted secondary processor [411fd073]
[ 0.309132] CPU4: Booted secondary processor [411fd073]
[ 0.341123] CPU5: Booted secondary processor [411fd073]
[ 0.341183] Brought up 6 CPUs
[ 0.341186] SMP: Total of 6 processors activated.
[ 0.341191] CPU features: detected feature: 32-bit EL0 Support
[ 0.341933] CPU: All CPU(s) started at EL2
[ 0.341982] alternatives: patching kernel code
[ 0.344731] devtmpfs: initialized
[ 0.386065] Initilizing CustomIPI irq domain
[ 0.386276] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.386287] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.394812] pinctrl core: initialized pinctrl subsystem
[ 0.395059] OS set in device tree is not L4T.
[ 0.395270] regulator-dummy: no parameters
[ 0.395410] Initializing plugin-manager
[ 0.395470] Plugin module not found
[ 0.395508] Plugin-manager status disabled
[ 0.397566] NET: Registered protocol family 16
[ 0.398400] pstore: using zlib compression
[ 0.398413] console [pstore-1] enabled
[ 0.398416] pstore: Registered ramoops as persistent store backend
[ 0.398419] ramoops: attached 0x200000@0x235880000, ecc: 0/0
[ 0.416702] cpuidle: using governor menu
[ 0.418371] bpmp: waiting for handshake
[ 0.418375] bpmp: handshake completed
[ 0.418386] bpmp: synchronizing channels
[ 0.418407] bpmp: channels synchronized
[ 0.418411] bpmp: mail init ok
[ 0.420586] arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.420591] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.420595] arm-smmu 12000000.iommu: stage 1 translation
[ 0.420598] arm-smmu 12000000.iommu: stage 2 translation
[ 0.420601] arm-smmu 12000000.iommu: nested translation
[ 0.420607] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.420613] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.420617] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.420621] arm-smmu 12000000.iommu: Stage-1: 39-bit VA → 48-bit IPA
[ 0.420625] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA → 48-bit PA
[ 0.422982] vdso: 2 pages (1 code @ ffffff8008f77000, 1 data @ ffffff8009e64000)
[ 0.422995] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.424982] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.427192] Registering BPMP clocks…
[ 0.427288] tegra_bpmp_clk_init: clock init ok (638 clks)
[ 0.428310] Serial: AMBA PL011 UART driver
[ 0.429420] tegra_powergate_init: DONE
[ 0.429428] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3489-1000-a00-00-base.dts
[ 0.429432] DTB Build time:
[ 0.431688] Tegra reboot handler registered.
[ 0.433256] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.433327] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.433339] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.433342] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L0
[ 0.433344] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.433505] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.433515] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.433852] iommu: Adding device 3460000.sdhci to group 0
[ 0.434330] iommu: Adding device 3440000.sdhci to group 1
[ 0.434786] iommu: Adding device 3400000.sdhci to group 2
[ 0.435880] iommu: Adding device 3507000.ahci-sata to group 3
[ 0.435893] arm-smmu: forcing sodev map for 3507000.ahci-sata
[ 0.436352] iommu: Adding device 3160000.i2c to group 4
[ 0.436837] iommu: Adding device c240000.i2c to group 5
[ 0.437198] iommu: Adding device 3180000.i2c to group 6
[ 0.437541] iommu: Adding device 3190000.i2c to group 7
[ 0.437961] iommu: Adding device 31b0000.i2c to group 8
[ 0.438297] iommu: Adding device 31c0000.i2c to group 9
[ 0.438631] iommu: Adding device c250000.i2c to group 10
[ 0.438965] iommu: Adding device 31e0000.i2c to group 11
[ 0.440461] iommu: Adding device 3210000.spi to group 12
[ 0.440839] iommu: Adding device c260000.spi to group 13
[ 0.441183] iommu: Adding device 3240000.spi to group 14
[ 0.441885] iommu: Adding device 3100000.serial to group 15
[ 0.442225] iommu: Adding device 3110000.serial to group 16
[ 0.442553] iommu: Adding device c280000.serial to group 17
[ 0.442884] iommu: Adding device 3130000.serial to group 18
[ 0.444256] iommu: Adding device 2490000.ether_qos to group 19
[ 0.444267] arm-smmu: forcing sodev map for 2490000.ether_qos
[ 0.445215] iommu: Adding device b000000.rtcpu to group 20
[ 0.447451] iommu: Adding device 13e10000.host1x to group 21
[ 0.447775] iommu: Adding device 13e10000.host1x:ctx0 to group 22
[ 0.448096] iommu: Adding device 13e10000.host1x:ctx1 to group 23
[ 0.448409] iommu: Adding device 13e10000.host1x:ctx2 to group 24
[ 0.448750] iommu: Adding device 13e10000.host1x:ctx3 to group 25
[ 0.449074] iommu: Adding device 13e10000.host1x:ctx4 to group 26
[ 0.449414] iommu: Adding device 13e10000.host1x:ctx5 to group 27
[ 0.449748] iommu: Adding device 13e10000.host1x:ctx6 to group 28
[ 0.450067] iommu: Adding device 13e10000.host1x:ctx7 to group 29
[ 0.450572] iommu: Adding device 150c0000.nvcsi to group 30
[ 0.451240] iommu: Adding device 15700000.vi to group 31
[ 0.451603] iommu: Adding device 15600000.isp to group 32
[ 0.452070] iommu: Adding device 15210000.nvdisplay to group 33
[ 0.452185] platform 15210000.nvdisplay: OF IOVA linear map 0x96081000 size (0x800000)
[ 0.452221] platform 15210000.nvdisplay: OF IOVA linear map 0x9607e000 size (0x2008)
[ 0.452778] iommu: Adding device 15340000.vic to group 34
[ 0.453010] iommu: Adding device 154c0000.nvenc to group 35
[ 0.453247] iommu: Adding device 15480000.nvdec to group 36
[ 0.453607] iommu: Adding device 15380000.nvjpg to group 37
[ 0.453833] iommu: Adding device 15500000.tsec to group 38
[ 0.454056] iommu: Adding device 15100000.tsecb to group 39
[ 0.454763] iommu: Adding device 15810000.se to group 40
[ 0.454989] iommu: Adding device 15820000.se to group 41
[ 0.455207] iommu: Adding device 15830000.se to group 42
[ 0.455439] iommu: Adding device 15840000.se to group 43
[ 0.456361] iommu: Adding device smmu_test to group 44
[ 0.457014] mc: mapped MMIO address: 0xffffff800a6c0000 → 0x2c10000
[ 0.457025] mc: mapped MMIO address: 0xffffff800a6e0000 → 0x2c20000
[ 0.457036] mc: mapped MMIO address: 0xffffff800a7b0000 → 0x2c30000
[ 0.457046] mc: mapped MMIO address: 0xffffff800a7d0000 → 0x2c40000
[ 0.457055] mc: mapped MMIO address: 0xffffff800b110000 → 0x2c50000
[ 0.457063] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.457073] mc-err: mcerr ops are set to t18x
[ 0.457248] dram-ecc: DRAM ECC enabled-MC_ECC_CONTROL:0x0000000d
[ 0.457274] dram-ecc: SCE-R5 is booted with Camera FW
[ 0.457277] dram-ecc: DRAM ECC interrupts handled in Camera FW
[ 0.458487] iommu: Adding device 3530000.xhci to group 45
[ 0.458500] arm-smmu: forcing sodev map for 3530000.xhci
[ 0.458972] iommu: Adding device 3550000.xudc to group 46
[ 0.458983] arm-smmu: forcing sodev map for 3550000.xudc
[ 0.459730] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_83 = 0x10a
[ 0.459736] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.459741] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 0.460390] iommu: Adding device 17000000.gp10b to group 47
[ 0.461538] tegra-reset 5000000.clock: registered 193 resets.
[ 0.463758] iommu: Adding device d000000.bpmp to group 48
[ 0.463973] bpmp: ping status is 0
[ 0.464071] bpmp d000000.bpmp: firmware tag is 91572a54614f84d0fd0c270beec2c56f
[ 0.466680] bpmp d000000.bpmp: probe ok
[ 0.469899] iommu: Adding device 2600000.dma to group 49
[ 0.471081] GPIO line 445 (sdmmc-wake-support-input) hogged as input
[ 0.471108] GPIO line 446 (sdmmc-wake-support-output) hogged as output/low
[ 0.471139] GPIO line 461 (camera-control-output-low) hogged as output/low
[ 0.471164] GPIO line 456 (camera-control-output-low) hogged as output/low
[ 0.471189] GPIO line 457 (camera-control-output-low) hogged as output/low
[ 0.471211] GPIO line 426 (camera-control-output-low) hogged as output/low
[ 0.471370] gpiochip_setup_dev: registered GPIOs 320 to 511 on device: gpiochip0 (tegra-gpio)
[ 0.475181] gpiochip_setup_dev: registered GPIOs 256 to 319 on device: gpiochip1 (tegra-gpio-aon)
[ 0.476748] iommu: Adding device 10003000.pcie-controller to group 50
[ 0.476763] arm-smmu: forcing sodev map for 10003000.pcie-controller
[ 0.477120] iommu: Adding device sound to group 51
[ 0.477488] iommu: Adding device 3510000.hda to group 52
[ 0.485226] iommu: Adding device c1a0000.aon to group 53
[ 0.485684] vdd-ac-bat: 5000 mV
[ 0.487437] vdd-1v8-ap: 1800 mV
[ 0.501356] random: fast init done
[ 0.513104] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.516414] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.516613] SCSI subsystem initialized
[ 0.516761] libata version 3.00 loaded.
[ 0.516919] usbcore: registered new interface driver usbfs
[ 0.516951] usbcore: registered new interface driver hub
[ 0.517012] usbcore: registered new device driver usb
[ 0.520156] GPIO line 241 (touch-rails) hogged as output/high
[ 0.520563] GPIO line 242 (touch-rails) hogged as output/high
[ 0.520752] gpiochip_setup_dev: registered GPIOs 240 to 255 on device: gpiochip2 (tca9539)
[ 0.522075] GPIO line 228 (lcd-bias-rails) hogged as output/high
[ 0.522210] gpiochip_setup_dev: registered GPIOs 224 to 239 on device: gpiochip3 (tca9539)
[ 0.532002] max77620 4-003c: PMIC Version OTP:0x4D and ES:0x1
[ 0.536903] vddio-ddr: at 1125 mV
[ 0.540701] avdd_dsi_csi: 1200 mV
[ 0.544694] vdd-1v8: 1800 mV
[ 0.548700] vdd-3v3-sys: 3300 mV
[ 0.549248] max77620-sd4: at 600 mV
[ 0.550176] spmic-ldo0: at 1800 mV
[ 0.550860] spmic-ldo1: at 800 mV
[ 0.552697] vddio-3v3: 3300 mV
[ 0.553267] vddio-sdmmc1: 1800 <–> 3300 mV at 3300 mV
[ 0.556717] vdd-rtc: at 800 mV
[ 0.557428] avdd-ts-hv: 1800 <–> 3300 mV at 1800 mV
[ 0.560696] spmic-ldo6: at 1500 mV
[ 0.564722] vdd-pex-1v00: 1000 mV
[ 0.565344] dvdd-pex: 1000 mV
[ 0.567494] GPIO line 221 (spmic_gpio_input) hogged as input
[ 0.567642] GPIO line 222 (spmic_gpio_input) hogged as input
[ 0.567795] gpiochip_setup_dev: registered GPIOs 216 to 223 on device: gpiochip4 (max77620-gpio)
[ 0.567971] max77620 4-003c: max77620 probe successful
[ 0.568366] media: Linux media interface: v0.10
[ 0.568395] Linux video capture interface: v2.00
[ 0.570910] pps_core: LinuxPPS API ver. 1 registered
[ 0.570913] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.570927] PTP clock support registered
[ 0.571116] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[ 0.571322] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.571339] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.572756] trusty trusty: trusty version: Built: 08:40:58 Feb 19 2021
[ 0.572771] trusty trusty: selected api version: 3 (requested 3)
[ 0.573625] Advanced Linux Sound Architecture Driver Initialized.
[ 0.573950] Bluetooth: Core ver 2.22
[ 0.573976] NET: Registered protocol family 31
[ 0.573978] Bluetooth: HCI device and connection manager initialized
[ 0.573985] Bluetooth: HCI socket layer initialized
[ 0.573989] Bluetooth: L2CAP socket layer initialized
[ 0.574003] Bluetooth: SCO socket layer initialized
[ 0.574752] en-vdd-sd: 3300 mV
[ 0.575429] en-vdd-cam: 1800 mV
[ 0.577154] vdd-hdmi: 5000 mV
[ 0.577487] vdd-usb0-5v: 5000 mV
[ 0.577774] vdd-usb1-5v: 5000 mV
[ 0.581156] en-vdd-ts-1v8: 1800 mV
[ 0.585140] en-vdd-ts-hv-3v3: 3300 mV
[ 0.585787] en-vdd-disp-3v3: 3300 mV
[ 0.586444] en-mdm-pwr-3v7: 3700 mV
[ 0.587094] en-vdd-disp-1v8: 1800 mV
[ 0.587745] en-vdd-cam-hv-2v8: 2800 mV
[ 0.588406] en-vdd-cam-1v2: 1200 mV
[ 0.589083] vdd-fan: 5000 mV
[ 0.589392] vdd-3v3: 3300 mV
[ 0.590301] dis-vdd-1v2: 1200 mV
[ 0.590557] en-vdd-vcm-2v8: 2800 mV
[ 0.591242] vdd-usb2-5v: 5000 mV
[ 0.591509] vdd-sys-bl: 3300 mV
[ 0.592206] en-vdd-sys: 1200 mV
[ 0.594364] camchar: rtcpu character device driver loaded
[ 0.594970] gpio tegra-gpio wake53 for gpio=159(X:7)
[ 0.596611] extcon-gpio-states external-connection:extcon@1: Cable state:1, cable id:2
[ 0.597545] clocksource: Switched to clocksource arch_sys_counter
[ 0.620143] VFS: Disk quotas dquot_6.6.0
[ 0.620218] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.620464] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.621042] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000c6000000, size=0x2a000000
[ 0.621182] cma: enabled page replacement for spfn=c6000, epfn=f0000
[ 0.621187] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.621195] nvmap: nvmap_select_cache_ops() nvmap cache ops set to roc
[ 0.621199] nvmap_page_pool_init: Total RAM pages: 1747779
[ 0.621203] nvmap_page_pool_init: nvmap page pool size: 218472 pages (853 MB)
[ 0.621248] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.621745] misc nvmap: created heap vpr base 0x00000000c6000000 size (688128KiB)
[ 0.623780] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 0.630033] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 0.630261] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 0.630704] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.630782] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.630892] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
[ 0.630995] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 0.631153] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type PMIC-Die
[ 0.631307] la/ptsa driver initialized.
[ 0.631317] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.631319] pre_t19x_iso_plat_init(): max_iso_bw=7680000KB
[ 0.631627] NET: Registered protocol family 2
[ 0.632302] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.632619] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.633231] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.633282] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.633400] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.633833] NET: Registered protocol family 1
[ 0.634213] RPC: Registered named UNIX socket transport module.
[ 0.634216] RPC: Registered udp transport module.
[ 0.634218] RPC: Registered tcp transport module.
[ 0.634220] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.634227] PCI: CLS 0 bytes, default 64
[ 0.634344] Trying to unpack rootfs image as initramfs…
[ 0.845440] Freeing initrd memory: 7064K
[ 0.861478] host1x 13e10000.host1x: initialized
[ 0.862864] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.865095] audit: initializing netlink subsys (disabled)
[ 0.865123] audit: type=2000 audit(0.756:1): initialized
[ 0.865606] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 0.872151] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.873159] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.873713] 9p: Installing v9fs 9p2000 file system support
[ 0.875913] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.875995] io scheduler noop registered
[ 0.876200] io scheduler cfq registered (default)
[ 0.879494] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 0.980410] iommu: Adding device aconnect@2a41000:adsp_audio to group 54
[ 1.013691] iommu: Adding device 2993000.adsp to group 55
[ 1.014725] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 1.017375] tegra-xusb-padctl 3520000.xusb_padctl: VBUS over-current detection enabled
[ 1.021016] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 1.022159] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 1.023229] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 1.024289] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.026787] tegra-pcie 10003000.pcie-controller: 4x1, 1x1 configuration
[ 1.027746] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[ 1.028078] tegra-pcie 10003000.pcie-controller: probing port 0, using 4 lanes
[ 1.028166] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.028280] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 1.028285] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=2000000, max_bw=4687500
[ 1.030629] tegra-pcie 10003000.pcie-controller: probing port 2, using 1 lanes
[ 1.031850] tsec 15500000.tsec: initialized
[ 1.032787] tsec 15100000.tsecb: initialized
[ 1.036360] nvdec 15480000.nvdec: initialized
[ 1.042480] falcon 15340000.vic: initialized
[ 1.043688] falcon 154c0000.nvenc: initialized
[ 1.044760] falcon 15380000.nvjpg: initialized
[ 1.046707] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 1.048133] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 1.049574] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 1.051004] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 1.052424] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 1.053869] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 1.055289] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 1.056711] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 1.060129] tegradccommon 15200000.dc_common: host1x channel mapped
[ 1.060137] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 1.060177] tegradccommon 15200000.dc_common: dma mapping done
[ 1.060354] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=391
[ 1.060436] tegra_cec 3960000.tegra_cec: Unpowergate DISP: 0.
[ 1.060657] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[ 1.060675] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[ 1.060839] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[ 1.060843] tegra_cec 3960000.tegra_cec: probed
[ 1.060909] tegradc 15210000.nvdisplay: disp0 connected to head1->/host1x/sor1
[ 1.060958] generic_infoframe_type: 0x87
[ 1.061057] tegradc 15210000.nvdisplay: DT parsed successfully
[ 1.061083] tegradc 15210000.nvdisplay: Display dc.ffffff800b650000 registered with id=0
[ 1.068892] pre_t19x_iso_plat_register(): iso bandwidth 5924200KB is not available, client disp_0
[ 1.068913] pre_t19x_iso_plat_register(): iso bandwidth 3136300KB is not available, client disp_0
[ 1.069006] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 2787800 KB/s
[ 1.069010] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 102000000 Hz
[ 1.069012] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 49070000 Hz
[ 1.069183] tegradc 15210000.nvdisplay: vblank syncpt # 8 for dc 1
[ 1.069189] tegradc 15210000.nvdisplay: vpulse3 syncpt # 9 for dc 1
[ 1.070482] tegradc 15210000.nvdisplay: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350937
[ 1.073294] tegradc 15210000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 1.073298] tegradc 15210000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 1.075394] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 32 channels
[ 1.075881] tegradc 15210000.nvdisplay: probed
[ 1.076014] tegra-fuse-burn 3820000.efuse:efuse-burn: shutdown limit check disabled
[ 1.076064] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 1.076734] kfuse 3830000.kfuse: initialized
[ 1.078387] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.081891] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.084318] console [ttyS0] disabled
[ 1.084363] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 36, base_baud = 25500000) is a Tegra
[ 1.102184] console [ttyS0] enabled
[ 1.102549] Console: switching to colour frame buffer device 240x67
[ 1.102636] tegradc 15210000.nvdisplay: fb registered
[ 1.102851] gpio tegra-gpio wake21 for gpio=121(P:1)
[ 1.103392] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 1.103448] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 1.103527] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 1.109298] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 37, base_baud = 0) is a TEGRA_UART
[ 1.110012] Parent Clock set for DC plld2
[ 1.110386] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 1.110560] serial-tegra 3130000.serial: RX in PIO mode
[ 1.111434] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 39, base_baud = 0) is a TEGRA_UART
[ 1.112502] [drm] Initialized
[ 1.119502] brd: module loaded
[ 1.123337] loop: module loaded
[ 1.123409] tegra_profiler: version: 1.143, samples/io: 48/28
[ 1.123481] tegra_profiler: auth: init
[ 1.123843] nct1008_nct72 7-004c: starting parse dt
[ 1.123940] nct1008_nct72 7-004c: !!!Found deprecated property!!!
[ 1.123945] nct1008_nct72 7-004c: success parsing dt
[ 1.124054] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 1.124430] THERMAL EST: found 3 subdevs
[ 1.124434] THERMAL EST num_resources: 0
[ 1.124438] [THERMAL EST subdev 0]
[ 1.124442] [THERMAL EST subdev 1]
[ 1.124446] [THERMAL EST subdev 2]
[ 1.124705] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 1.124707] THERMAL EST: thz register success.
[ 1.124797] THERMAL EST: end of probe, return err: 0
[ 1.125409] sd: No Scsi addr parsed to reserve index
[ 1.125431] hisi_sas: driver version v1.6
[ 1.132959] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 1.132966] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 1.133784] scsi host0: tegra_ahci
[ 1.138190] scsi host1: tegra_ahci
[ 1.138338] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 24
[ 1.138341] ata2: DUMMY
[ 1.143496] libphy: Fixed MDIO Bus: probed
[ 1.144025] tun: Universal TUN/TAP device driver, 1.6
[ 1.144028] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 1.144717] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.144720] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.144756] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.144758] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.144787] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.144789] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.144822] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 1.144824] Copyright(c) 1999 - 2017 Intel Corporation.
[ 1.156497] nct1008_nct72 7-004c: LOC shutdown limit 110
[ 1.156972] nct1008_nct72 7-004c: EXT shutdown limit 110
[ 1.157639] eqos 2490000.ether_qos: can’t get pllrefe_vcoout clk (-2)
[ 1.159985] eqos 2490000.ether_qos: failed to read eqos_auto_cal_config_0_reg
[ 1.160457] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b c7 92 5
[ 1.160556] libphy: dwc_phy: probed
[ 1.160862] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 1.162371] tegradc 15210000.nvdisplay: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_111m_223m
[ 1.163665] PPP generic driver version 2.4.2
[ 1.163782] PPP BSD Compression module registered
[ 1.163785] PPP Deflate Compression module registered
[ 1.163798] PPP MPPE Compression module registered
[ 1.163802] NET: Registered protocol family 24
[ 1.163843] usbcore: registered new interface driver r8152
[ 1.163870] usbcore: registered new interface driver asix
[ 1.163899] usbcore: registered new interface driver ax88179_178a
[ 1.163924] usbcore: registered new interface driver cdc_ether
[ 1.163952] usbcore: registered new interface driver net1080
[ 1.163960] tegradc 15210000.nvdisplay: hdmi: get RGB quant from REG programmed by BL.
[ 1.163968] tegradc 15210000.nvdisplay: hdmi: get YCC quant from REG programmed by BL.
[ 1.163976] usbcore: registered new interface driver cdc_subset
[ 1.164005] usbcore: registered new interface driver zaurus
[ 1.164041] usbcore: registered new interface driver cdc_ncm
[ 1.164167] VFIO - User Level meta-driver version: 0.3
[ 1.165065] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.165077] ehci-pci: EHCI PCI platform driver
[ 1.165109] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.165125] ohci-pci: OHCI PCI platform driver
[ 1.165156] ohci-platform: OHCI generic platform driver
[ 1.170210] tegra-xusb 3530000.xhci: USB2 port 0 has OTG_CAP
[ 1.171840] tegra-xusb 3530000.xhci: extcon 0: ffffffc1ac081000 id
[ 1.172579] usbcore: registered new interface driver uas
[ 1.172618] usbcore: registered new interface driver usb-storage
[ 1.172684] usbcore: registered new interface driver usbserial
[ 1.173572] tegra-xusb 3530000.xhci: Firmware timestamp: 2019-10-31 05:52:15 UTC, Version: 55.17 release
[ 1.177293] tegra-xudc-new 3550000.xudc: device count: 1
[ 1.178371] tegra-xudc-new 3550000.xudc: vbus state: 0
[ 1.178841] mousedev: PS/2 mouse device common for all mice
[ 1.178889] usbcore: registered new interface driver xpad
[ 1.181666] tegra-xudc-new 3550000.xudc: entering ELPG
[ 1.183060] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 1.188992] nct1008_nct72 7-004c: initial LOC temp: 32000
[ 1.189284] nct1008_nct72 7-004c: initial EXT temp: 45500
[ 1.189860] nct1008_nct72 7-004c: hi_b:-11, lo_b:0
[ 1.190149] gpio tegra-gpio-aon wake35 for gpio=16(V:0)
[ 1.190334] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 1.190747] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 1.190751] Extcon AUX1(HDMI) enable
[ 1.193767] extcon-gpio-states external-connection:extcon@1: Cable state:0, cable id:0
[ 1.201870] tegra-xusb 3530000.xhci: xHCI Host Controller
[ 1.201888] tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 1
[ 1.202573] tegra-xusb 3530000.xhci: hcc params 0x0184fd25 hci version 0x100 quirks 0x00050810
[ 1.202601] tegra-xusb 3530000.xhci: irq 71, io mem 0x03530000
[ 1.202740] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.202745] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.202749] usb usb1: Product: xHCI Host Controller
[ 1.202753] usb usb1: Manufacturer: Linux 4.9.201-tegra xhci-hcd
[ 1.202756] usb usb1: SerialNumber: 3530000.xhci
[ 1.203089] hub 1-0:1.0: USB hub found
[ 1.203116] hub 1-0:1.0: 4 ports detected
[ 1.203448] tegra-xusb 3530000.xhci: xHCI Host Controller
[ 1.203456] tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 2
[ 1.203583] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.203588] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.203591] usb usb2: Product: xHCI Host Controller
[ 1.203595] usb usb2: Manufacturer: Linux 4.9.201-tegra xhci-hcd
[ 1.203598] usb usb2: SerialNumber: 3530000.xhci
[ 1.203879] hub 2-0:1.0: USB hub found
[ 1.203904] hub 2-0:1.0: 3 ports detected
[ 1.204356] Wake76 for irq=199
[ 1.204358] Wake77 for irq=199
[ 1.204360] Wake78 for irq=199
[ 1.204362] Wake79 for irq=199
[ 1.204364] Wake80 for irq=199
[ 1.204366] Wake81 for irq=199
[ 1.204368] Wake82 for irq=199
[ 1.204392] tegra-xusb 3530000.xhci: Upgrade port 0 to USB3.0
[ 1.204396] tegra-xusb 3530000.xhci: Upgrade port 1 to USB3.0
[ 1.291661] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.292788] Wake73 for irq=42
[ 1.294041] rtc rtc1: alarm rtc device
[ 1.294053] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 1.294069] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 1.294271] i2c /dev entries driver
[ 1.297596] max77620-power max20024-power: Event recorder REG_NVERC : 0x0
[ 1.302507] parse_throttle_dt_data: Num cap clks = 4
[ 1.302511] parse_throttle_dt_data: clk=mcpu type=1
[ 1.302514] parse_throttle_dt_data: clk=bcpu type=2
[ 1.302522] parse_throttle_dt_data: clk=gpu type=4
[ 1.302524] parse_throttle_dt_data: clk=emc type=3
[ 1.303504] tegra_throttle_probe: probe successful. #cdevs=4
[ 1.304087] FAN dev name: pwm-fan
[ 1.304152] FAN:gpio request success.
[ 1.304160] FAN: can’t find tach_gpio
[ 1.304184] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 1.304373] pwm_fan_driver pwm-fan: got pwm for fan. polarity is inversed
[ 1.304378] pwm_fan_driver pwm-fan: tach period: 1000
[ 1.304941] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 1.304945] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 1.304950] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 1.304954] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 1.304958] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 1.304962] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 1.304965] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 1.304969] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 1.304973] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 1.304977] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 1.305514] tegra-oc-event d280000.soctherm-oc-event: OC driver initialized
[ 1.305762] usb usb1: usb_suspend_both: status 0
[ 1.306518] device-mapper: uevent: version 1.0.3
[ 1.306857] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 1.307127] CPU EMC frequency mapping table: default setting
[ 1.309213] cpufreq: platform driver Initialization: pass
[ 1.309891] cpuidle: Initializing cpuidle driver init for Denver cluster
[ 1.310013] cpuidle: Initializing cpuidle driver init for A57 cluster
[ 1.311018] sdhci: Secure Digital Host Controller Interface driver
[ 1.311020] sdhci: Copyright(c) Pierre Ossman
[ 1.311021] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.312224] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 1.315078] CMDQ: cmdq_platfm_init successful
[ 1.316078] CQE: CMD_TIMING bit set for R1B DCMD
[ 1.318605] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 1.321720] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 1.321771] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 1.322381] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 1.324187] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 258
[ 1.326209] tegradc 15210000.nvdisplay: blank - powerdown
[ 1.327608] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 1.328496] tegra-se-nvhost 15810000.se: initialized
[ 1.329684] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 1.330293] tegra-se-nvhost 15820000.se: initialized
[ 1.331296] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 1.331864] tegra-se-nvhost 15830000.se: initialized
[ 1.332724] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 1.333283] tegra-se-nvhost 15840000.se: initialized
[ 1.334336] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 1.334602] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.335553] usbcore: registered new interface driver usbhid
[ 1.335554] usbhid: USB HID core driver
[ 1.342843] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 1.345023] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xbfef0000-0xbfefdb7f size=56192
[ 1.345276] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 1.345425] tegra-ivc ivc-b000000.rtcpu:i2c@480: i2c: ver=0 grp=1 RX[8x128]=0x1900-0x1d80 TX[8x128]=0x1d80-0x2200
[ 1.345675] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x2200-0x4280 TX[64x128]=0x4280-0x6300
[ 1.346651] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x6300-0x63c0 TX[1x64]=0x63c0-0x6480
[ 1.346752] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x6480-0x7900 TX[16x320]=0x7900-0x8d80
[ 1.346843] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8d80-0x9200 TX[16x64]=0x9200-0x9680
[ 1.346894] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x9680-0x9880 TX[1x384]=0x9880-0x9a80
[ 1.346998] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x8192]=0x9a80-0xbb00 TX[1x8192]=0xbb00-0xdb80
[ 1.347376] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (52)
[ 1.347379] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 1.347891] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=5 sha1=3ecb1dca25fa98771f988f238c025334776c9a96
[ 1.349726] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 1.350202] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 1.350370] register_ari_mca_banks: Registered MCA ROC:IOB
[ 1.350444] register_ari_mca_banks: Registered MCA ROC:CCE
[ 1.350808] tegra18-bridge 2390000.axi2apb: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 1.350810] tegra18-bridge 2390000.axi2apb: enabled timeout = 16684000
[ 1.350812] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ 1.350868] tegra18-bridge 23a0000.axi2apb: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 1.350870] tegra18-bridge 23a0000.axi2apb: enabled timeout = 16684000
[ 1.350872] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ 1.350923] tegra18-bridge 23b0000.axi2apb: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 1.350925] tegra18-bridge 23b0000.axi2apb: enabled timeout = 16684000
[ 1.350926] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ 1.350976] tegra18-bridge 23c0000.axi2apb: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 1.350978] tegra18-bridge 23c0000.axi2apb: enabled timeout = 16684000
[ 1.350979] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ 1.351028] tegra18-bridge 23d0000.axi2apb: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 1.351029] tegra18-bridge 23d0000.axi2apb: enabled timeout = 16684000
[ 1.351031] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ 1.351078] tegra18-bridge 2100000.axip2p: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 1.351081] tegra18-bridge 2100000.axip2p: enabled timeout = 16684000
[ 1.351083] tegra18-bridge 2100000.axip2p: bridge probed OK
[ 1.351132] tegra18-bridge 2110000.axip2p: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 1.351135] tegra18-bridge 2110000.axip2p: enabled timeout = 16684000
[ 1.351137] tegra18-bridge 2110000.axip2p: bridge probed OK
[ 1.351184] tegra18-bridge 2120000.axip2p: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 1.351187] tegra18-bridge 2120000.axip2p: enabled timeout = 16684000
[ 1.351189] tegra18-bridge 2120000.axip2p: bridge probed OK
[ 1.351245] tegra18-bridge 2130000.axip2p: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 1.351249] tegra18-bridge 2130000.axip2p: enabled timeout = 16684000
[ 1.351250] tegra18-bridge 2130000.axip2p: bridge probed OK
[ 1.351311] tegra18-bridge 2140000.axip2p: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 1.351313] tegra18-bridge 2140000.axip2p: enabled timeout = 16684000
[ 1.351315] tegra18-bridge 2140000.axip2p: bridge probed OK
[ 1.351364] tegra18-bridge 2150000.axip2p: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 1.351368] tegra18-bridge 2150000.axip2p: enabled timeout = 16684000
[ 1.351370] tegra18-bridge 2150000.axip2p: bridge probed OK
[ 1.351416] tegra18-bridge 2160000.axip2p: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 1.351420] tegra18-bridge 2160000.axip2p: enabled timeout = 16684000
[ 1.351421] tegra18-bridge 2160000.axip2p: bridge probed OK
[ 1.351470] tegra18-bridge 2170000.axip2p: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 1.351474] tegra18-bridge 2170000.axip2p: enabled timeout = 16684000
[ 1.351475] tegra18-bridge 2170000.axip2p: bridge probed OK
[ 1.351526] tegra18-bridge 2180000.axip2p: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 1.351530] tegra18-bridge 2180000.axip2p: enabled timeout = 16684000
[ 1.351531] tegra18-bridge 2180000.axip2p: bridge probed OK
[ 1.351578] tegra18-bridge 2190000.axip2p: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 1.351581] tegra18-bridge 2190000.axip2p: enabled timeout = 16684000
[ 1.351582] tegra18-bridge 2190000.axip2p: bridge probed OK
[ 1.351640] **** A57 ECC: Enabled
[ 1.351642] tegra18_a57_serr_init: on CPU 4 a A57 Core
[ 1.351707] tegra18x_actmon d230000.actmon: in actmon_register()…
[ 1.352155] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 1.352629] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 1.352760] denver_knobs_init:MTS_VERSION:47926945
[ 1.354809] nvpmodel: initialized successfully
[ 1.355781] trusty-virtio trusty:virtio: initializing
[ 1.355891] trusty_ipc virtio0: vring0: va¶ ffffffc1a76fc000(0) qsz 32 notifyid 1
[ 1.355898] trusty_ipc virtio0: vring1: va¶ ffffffc1a76fe000(0) qsz 32 notifyid 2
[ 1.355970] trusty-virtio trusty:virtio: initializing done
[ 1.356109] trusty_ipc virtio0: is online
[ 1.357569] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 1.357680] usbcore: registered new interface driver snd-usb-audio
[ 1.361565] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 1.362679] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 1.362680] Extcon AUX1(HDMI) disable
[ 1.374158] gpio tegra-gpio wake71 for gpio=125(P:5)
[ 1.374208] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 1.377453] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 1.377642] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 1.385327] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[ 1.385730] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 1.386454] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 1.391493] OPE platform probe
[ 1.391568] OPE platform probe successful
[ 1.392952] tegradc 15210000.nvdisplay: unblank
[ 1.393790] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 1.393919] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 1.394205] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 1.396296] Parent Clock set for DC plld2
[ 1.399833] tegradc 15210000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 1.401182] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[ 1.426942] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[ 1.437172] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 1.437174] Extcon AUX1(HDMI) enable
[ 1.439856] mmc0: periodic cache flush enabled
[ 1.439864] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 1.440220] mmcblk0: mmc0:0001 032G34 29.1 GiB
[ 1.440335] mmcblk0boot0: mmc0:0001 032G34 partition 1 8.00 MiB
[ 1.444478] mmcblk0boot1: mmc0:0001 032G34 partition 2 8.00 MiB
[ 1.444588] mmcblk0rpmb: mmc0:0001 032G34 partition 3 4.00 MiB
[ 1.447959] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 1.448044] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 1.448115] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 1.448190] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 1.448260] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 1.448331] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 1.448405] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 1.448475] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 1.448547] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 1.448618] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 1.448690] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 1.448762] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 1.448836] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 1.448838] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29 p30 p31 p32 p33
[ 1.448856] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 1.448915] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 1.448999] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 1.449082] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 1.449166] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 1.449245] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 1.449323] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 1.449399] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 1.451340] tegradc 15210000.nvdisplay: sync windows ret = 246
[ 1.451946] ata1: SATA link down (SStatus 0 SControl 300)
[ 1.474234] u32 classifier
[ 1.474236] Actions configured
[ 1.474300] Initializing XFRM netlink socket
[ 1.474477] extcon-disp-state external-connection:disp-state: cable 51 state 1
[ 1.474479] Extcon HDMI: HPD enabled
[ 1.474498] tegradc 15210000.nvdisplay: hdmi: plugged
[ 1.474916] NET: Registered protocol family 10
[ 1.475584] NET: Registered protocol family 17
[ 1.475596] NET: Registered protocol family 15
[ 1.475660] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.475703] Bluetooth: RFCOMM socket layer initialized
[ 1.475713] Bluetooth: RFCOMM ver 1.11
[ 1.475717] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.475721] Bluetooth: HIDP socket layer initialized
[ 1.475737] 9pnet: Installing 9P2000 support
[ 1.475773] Key type dns_resolver registered
[ 1.476084] Registered cp15_barrier emulation handler
[ 1.476097] Registered setend emulation handler
[ 1.477032] registered taskstats version 1
[ 1.481515] isp 15600000.isp: initialized
[ 1.486338] nvcsi 150c0000.nvcsi: initialized
[ 1.488191] tegra-vi4 15700000.vi: using default number of vi channels,15
[ 1.491080] Wake83 for irq=51
[ 1.491154] gpio tegra-gpio-aon wake29 for gpio=56(FF:0)
[ 1.491223] gpio tegra-gpio-aon wake67 for gpio=57(FF:1)
[ 1.491293] gpio tegra-gpio-aon wake68 for gpio=58(FF:2)
[ 1.491427] input: gpio-keys as /devices/gpio-keys/input/input2
[ 1.492745] tegra-vi4 15700000.vi: initialized
[ 1.493594] tegra-vi4 15700000.vi: ep of_device is not enabled /host1x/vi@15700000/ports/port@0/endpoint.
[ 1.493599] tegra-vi4 15700000.vi: ep of_device is not enabled /host1x/vi@15700000/ports/port@1/endpoint.
[ 1.522239] tegra_rtc c2a0000.rtc: setting system clock to 2000-01-01 01:00:10 UTC (946688410)
[ 1.523674] mmcblk mmc0:0001: Card claimed for testing.
[ 1.529925] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 1.546377] bpmp: mounted debugfs mirror
[ 1.547692] bwmgr: missing cdev-type property
[ 1.552682] ALSA device list:
[ 1.552687] #0: tegra-hda at 0x3518000 irq 384
[ 1.552689] #1: tegra-snd-t186ref-mobile-rt565x
[ 1.554671] usb 2-1: New USB device found, idVendor=05e3, idProduct=0626
[ 1.554676] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.554679] usb 2-1: Product: USB3.1 Hub
[ 1.554682] usb 2-1: Manufacturer: GenesysLogic
[ 1.555279] Freeing unused kernel memory: 8576K
[ 1.557799] hub 2-1:1.0: USB hub found
[ 1.558140] hub 2-1:1.0: 4 ports detected
[ 1.578935] Root device found: mmcblk0p1
[ 1.580091] Found dev node: /dev/mmcblk0p1
[ 1.669567] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 1.692413] usb 1-2: New USB device found, idVendor=05e3, idProduct=0610
[ 1.692418] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.692421] usb 1-2: Product: USB2.1 Hub
[ 1.692423] usb 1-2: Manufacturer: GenesysLogic
[ 1.693278] hub 1-2:1.0: USB hub found
[ 1.693558] hub 1-2:1.0: 4 ports detected
[ 1.713562] usb 2-1: usb_suspend_both: status 0
[ 1.713679] usb usb2: usb_suspend_both: status 0
[ 1.823896] EXT4-fs (mmcblk0p1): recovery complete
[ 1.824456] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 1.826447] Rootfs mounted over mmcblk0p1
[ 1.851568] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 1.853521] Switching from initrd to actual rootfs
[ 1.975940] systemd[1]: System time before build time, advancing clock.
[ 1.997643] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.005570] usb 1-2.2: new low-speed USB device number 3 using tegra-xusb
[ 2.007027] cgroup: cgroup2: unknown option “nsdelegate”
[ 2.023659] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 2.024437] systemd[1]: Detected architecture arm64.
[ 2.031174] usb 1-2.2: New USB device found, idVendor=c0f4, idProduct=04c0
[ 2.031178] usb 1-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.031181] usb 1-2.2: Product: usb keyboard
[ 2.031184] usb 1-2.2: Manufacturer: SZH
[ 2.034414] input: SZH usb keyboard as /devices/3530000.xhci/usb1/1-2/1-2.2/1-2.2:1.0/0003:C0F4:04C0.0001/input/input3
[ 2.048408] systemd[1]: Set hostname to .
[ 2.085604] tegra_cec 3960000.tegra_cec: physical address: 10:00.
[ 2.093974] hid-generic 0003:C0F4:04C0.0001: input,hidraw0: USB HID v1.10 Keyboard [SZH usb keyboard] on usb-3530000.xhci-2.2/input0
[ 2.097298] input: SZH usb keyboard as /devices/3530000.xhci/usb1/1-2/1-2.2/1-2.2:1.1/0003:C0F4:04C0.0002/input/input4
[ 2.150123] tegra_cec 3960000.tegra_cec: Sent res: -113.
[ 2.150128] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[ 2.153429] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 2.153436] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 2.153806] hid-generic 0003:C0F4:04C0.0002: input,hidraw1: USB HID v1.10 Device [SZH usb keyboard] on usb-3530000.xhci-2.2/input1
[ 2.257565] usb 1-2.3: new low-speed USB device number 4 using tegra-xusb
[ 2.259649] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 2.261665] tegra-pcie 10003000.pcie-controller: link 0 down, ignoring
[ 2.276667] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.278217] systemd[1]: Created slice System Slice.
[ 2.278523] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.278635] systemd[1]: Listening on Journal Audit Socket.
[ 2.278675] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.278748] systemd[1]: Listening on udev Kernel Socket.
[ 2.278874] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 2.279794] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 2.282966] usb 1-2.3: New USB device found, idVendor=1c4f, idProduct=0034
[ 2.282971] usb 1-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.282973] usb 1-2.3: Product: Usb Mouse
[ 2.282976] usb 1-2.3: Manufacturer: SIGMACHIP
[ 2.286265] input: SIGMACHIP Usb Mouse as /devices/3530000.xhci/usb1/1-2/1-2.3/1-2.3:1.0/0003:1C4F:0034.0003/input/input5
[ 2.286519] hid-generic 0003:1C4F:0034.0003: input,hidraw2: USB HID v1.10 Mouse [SIGMACHIP Usb Mouse] on usb-3530000.xhci-2.3/input0
[ 2.303596] random: crng init done
[ 2.303600] random: 7 urandom warning(s) missed due to ratelimiting
[ 2.342118] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 2.389597] usb 1-2.4: new full-speed USB device number 5 using tegra-xusb
[ 2.424621] usb 1-2.4: New USB device found, idVendor=0403, idProduct=6001
[ 2.424627] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.424630] usb 1-2.4: Product: FT232R USB UART
[ 2.424633] usb 1-2.4: Manufacturer: FTDI
[ 2.424636] usb 1-2.4: SerialNumber: AR0JVBQD
[ 2.448988] bcpu-throttle-alert cooling device registered.
[ 2.449150] mcpu-throttle-alert cooling device registered.
[ 2.449314] gpu-throttle-alert cooling device registered.
[ 2.652451] systemd-journald[2294]: Received request to flush runtime journal from PID 1
[ 2.667591] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 3.077589] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 3.312338] using random self ethernet address
[ 3.331039] using random host ethernet address
[ 3.384673] usbcore: registered new interface driver ftdi_sio
[ 3.384715] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 3.384829] ftdi_sio 1-2.4:1.0: FTDI USB Serial Device converter detected
[ 3.401945] usb 1-2.4: Detected FT232RL
[ 3.404473] usb 1-2.4: FTDI USB Serial Device converter now attached to ttyUSB0
[ 3.510811] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 3.512862] tegra-pcie 10003000.pcie-controller: link 2 down, ignoring
[ 3.716181] tegra-pcie 10003000.pcie-controller: PCIE: no end points detected
[ 3.716675] tegra-pcie 10003000.pcie-controller: PCIE: Disable power rails
[ 3.856197] Mass Storage Function, version: 2009/09/11
[ 3.856203] LUN: removable file: (no medium)
[ 3.868970] using random self ethernet address
[ 3.905524] using random host ethernet address
[ 3.940599] rndis0: HOST MAC 42:24:f3:35:b9:08
[ 3.941111] rndis0: MAC 42:24:f3:35:b9:09
[ 3.941644] usb0: HOST MAC 42:24:f3:35:b9:0a
[ 3.941681] usb0: MAC 42:24:f3:35:b9:0b
[ 3.941704] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 3.943778] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 3.943801] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
[ 3.943833] tegra-xudc-new 3550000.xudc: entering ELPG
[ 3.945143] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 3.945162] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 3.947044] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 3.947059] tegra-xudc-new 3550000.xudc: entering ELPG
[ 3.948300] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 3.954868] l4tbr0: port 1(rndis0) entered blocking state
[ 3.954874] l4tbr0: port 1(rndis0) entered disabled state
[ 3.955501] device rndis0 entered promiscuous mode
[ 3.961763] extcon-gpio-states external-connection:extcon@1: Cable state:0, cable id:0
[ 3.972799] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 3.977732] l4tbr0: port 2(usb0) entered blocking state
[ 3.977737] l4tbr0: port 2(usb0) entered disabled state
[ 3.977899] device usb0 entered promiscuous mode
[ 4.001040] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 4.240620] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 4.319699] gpio tegra-gpio wake18 for gpio=101(M:5)
[ 4.324310] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 4.358613] zram: Added device: zram0
[ 4.363950] zram: Added device: zram1
[ 4.364377] zram: Added device: zram2
[ 4.364783] zram: Added device: zram3
[ 4.365195] zram: Added device: zram4
[ 4.366366] zram: Added device: zram5
[ 4.416089] zram0: detected capacity change from 0 to 597909504
[ 4.469388] Adding 583892k swap on /dev/zram0. Priority:5 extents:1 across:583892k SS
[ 4.473120] zram1: detected capacity change from 0 to 597909504
[ 4.493395] Adding 583892k swap on /dev/zram1. Priority:5 extents:1 across:583892k SS
[ 4.502771] zram2: detected capacity change from 0 to 597909504
[ 4.521358] Adding 583892k swap on /dev/zram2. Priority:5 extents:1 across:583892k SS
[ 4.531336] zram3: detected capacity change from 0 to 597909504
[ 4.553431] Adding 583892k swap on /dev/zram3. Priority:5 extents:1 across:583892k SS
[ 4.565120] zram4: detected capacity change from 0 to 597909504
[ 4.593931] Adding 583892k swap on /dev/zram4. Priority:5 extents:1 across:583892k SS
[ 4.597120] zram5: detected capacity change from 0 to 597909504
[ 4.616940] Adding 583892k swap on /dev/zram5. Priority:5 extents:1 across:583892k SS
[ 5.439928] tegradc 15210000.nvdisplay: unblank
[ 6.171098] fuse init (API version 7.26)
[ 7.364528] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 7.365230] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 8.899260] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 8.899272] Bluetooth: BNEP socket layer initialized
[ 10.025738] extcon-gpio-states external-connection:extcon@1: Cable state:0, cable id:0
[ 31.814368] spmic-ldo0: disabling
[ 31.814610] spmic-ldo1: disabling
[ 31.814797] en-vdd-sd: disabling
[ 31.814808] en-vdd-cam: disabling
[ 31.814820] vdd-usb0-5v: disabling
[ 31.814829] vdd-usb1-5v: disabling
[ 31.814841] en-vdd-disp-3v3: disabling
[ 31.814850] en-mdm-pwr-3v7: disabling
[ 31.814859] en-vdd-disp-1v8: disabling
[ 31.814868] en-vdd-cam-hv-2v8: disabling
[ 31.814877] en-vdd-cam-1v2: disabling
[ 31.814887] vdd-fan: disabling
[ 31.814896] vdd-3v3: disabling
[ 31.814906] en-vdd-vcm-2v8: disabling
[ 31.814917] vdd-sys-bl: disabling
[ 31.814927] en-vdd-sys: disabling
[ 47.145994] tegradc 15210000.nvdisplay: blank - powerdown
[ 47.201813] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 47.201817] Extcon AUX1(HDMI) disable
[ 47.223379] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[ 47.223468] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 47.223970] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 47.354562] tegradc 15210000.nvdisplay: blank - powerdown
[ 47.354573] tegradc 15210000.nvdisplay: unblank
[ 47.355175] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 47.355264] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 47.355345] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 47.356669] Parent Clock set for DC plld2
[ 47.360145] tegradc 15210000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 47.361358] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[ 47.399068] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 47.399071] Extcon AUX1(HDMI) enable
[ 47.399286] tegradc 15210000.nvdisplay: unblank
[ 50.733751] tegradc 15210000.nvdisplay: unblank
[ 164.603287] usb 1-2-port2: disabled by hub (EMI?), re-enabling…
[ 164.609881] usb 1-2.2: USB disconnect, device number 3
[ 164.703212] extcon-gpio-states external-connection:extcon@1: Cable state:1, cable id:1
[ 164.703311] tegra-xudc-new 3550000.xudc: vbus state: 1
[ 164.719608] extcon-gpio-states external-connection:extcon@1: Cable state:1, cable id:2
[ 164.871087] tegra-usb-cd usb_cd: notification status (0x0, 0x1)
[ 164.871093] tegra-usb-cd usb_cd: connected to SDP
[ 164.871106] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 164.872912] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 164.872920] tegra-xudc-new 3550000.xudc: device mode on: 0
[ 164.872932] tegra-xudc-new 3550000.xudc: active: 0 => 1
[ 164.872937] tegra-xudc-new 3550000.xudc: vbus state: 0
[ 164.872942] tegra-xudc-new 3550000.xudc: device mode off: 0
[ 164.873077] tegra-usb-cd usb_cd: notification status (0x1, 0x0)
[ 164.873082] tegra-usb-cd usb_cd: disconnected USB cable/charger
[ 164.873092] tegra-xudc-new 3550000.xudc: active: 1 => 0
[ 164.873137] tegra-xudc-new 3550000.xudc: entering ELPG
[ 164.879115] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 164.887232] extcon-gpio-states external-connection:extcon@1: Cable state:1, cable id:2
[ 165.019128] usb 1-2.2: new low-speed USB device number 6 using tegra-xusb
[ 165.045670] usb 1-2.2: New USB device found, idVendor=c0f4, idProduct=04c0
[ 165.045699] usb 1-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 165.045718] usb 1-2.2: Product: usb keyboard
[ 165.045732] usb 1-2.2: Manufacturer: SZH
[ 165.051415] input: SZH usb keyboard as /devices/3530000.xhci/usb1/1-2/1-2.2/1-2.2:1.0/0003:C0F4:04C0.0004/input/input6
[ 165.112720] hid-generic 0003:C0F4:04C0.0004: input,hidraw0: USB HID v1.10 Keyboard [SZH usb keyboard] on usb-3530000.xhci-2.2/input0
[ 165.116814] input: SZH usb keyboard as /devices/3530000.xhci/usb1/1-2/1-2.2/1-2.2:1.1/0003:C0F4:04C0.0005/input/input7
[ 165.176007] hid-generic 0003:C0F4:04C0.0005: input,hidraw1: USB HID v1.10 Device [SZH usb keyboard] on usb-3530000.xhci-2.2/input1
[ 165.176803] usb 1-2-port3: disabled by hub (EMI?), re-enabling…
[ 165.183788] usb 1-2.3: USB disconnect, device number 4
[ 165.479053] usb 1-2.3: new low-speed USB device number 7 using tegra-xusb
[ 165.505029] usb 1-2.3: New USB device found, idVendor=1c4f, idProduct=0034
[ 165.505060] usb 1-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 165.505077] usb 1-2.3: Product: Usb Mouse
[ 165.505091] usb 1-2.3: Manufacturer: SIGMACHIP
[ 165.513057] input: SIGMACHIP Usb Mouse as /devices/3530000.xhci/usb1/1-2/1-2.3/1-2.3:1.0/0003:1C4F:0034.0006/input/input8
[ 165.513371] hid-generic 0003:1C4F:0034.0006: input,hidraw2: USB HID v1.10 Mouse [SIGMACHIP Usb Mouse] on usb-3530000.xhci-2.3/input0
[ 498.122306] tegradc 15210000.nvdisplay: blank - powerdown
[ 498.177992] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 498.177995] Extcon AUX1(HDMI) disable
[ 498.199790] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[ 498.199887] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 498.200405] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 498.779616] extcon-disp-state external-connection:disp-state: cable 51 state 0
[ 498.779620] Extcon HDMI: HPD disabled
[ 498.779644] tegradc 15210000.nvdisplay: hdmi: unplugged
[ 498.795369] tegradc 15210000.nvdisplay: blank - powerdown
[ 498.795380] tegradc 15210000.nvdisplay: unblank
[ 498.795394] tegradc 15210000.nvdisplay: unblank
[ 500.424124] tegradc 15210000.nvdisplay: blank - powerdown
[ 500.424143] tegradc 15210000.nvdisplay: unblank
[ 500.424853] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 500.424937] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 500.425018] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 500.427069] Parent Clock set for DC plld2
[ 500.431802] tegradc 15210000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 500.432983] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[ 500.469110] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 500.469113] Extcon AUX1(HDMI) enable
[ 500.469408] extcon-disp-state external-connection:disp-state: cable 51 state 1
[ 500.469412] Extcon HDMI: HPD enabled
[ 500.469442] tegradc 15210000.nvdisplay: hdmi: plugged
[ 500.474792] tegradc 15210000.nvdisplay: unblank
[ 500.495496] tegradc 15210000.nvdisplay: unblank
[ 1009.565442] tegradc 15210000.nvdisplay: blank - powerdown
[ 1009.616122] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 1009.616133] Extcon AUX1(HDMI) disable
[ 1009.638074] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[ 1009.638172] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 1009.638698] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 1010.219702] extcon-disp-state external-connection:disp-state: cable 51 state 0
[ 1010.219717] Extcon HDMI: HPD disabled
[ 1010.219922] tegradc 15210000.nvdisplay: hdmi: unplugged
[ 1010.229196] tegradc 15210000.nvdisplay: blank - powerdown
[ 1010.229217] tegradc 15210000.nvdisplay: unblank
[ 1010.229230] tegradc 15210000.nvdisplay: unblank
[ 1011.863880] tegradc 15210000.nvdisplay: blank - powerdown
[ 1011.863925] tegradc 15210000.nvdisplay: unblank
[ 1011.864684] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 1011.864803] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 1011.864913] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 1011.867314] Parent Clock set for DC plld2
[ 1011.872314] tegradc 15210000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 1011.873825] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[ 1011.909891] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 1011.909899] Extcon AUX1(HDMI) enable
[ 1011.916020] tegradc 15210000.nvdisplay: unblank
[ 1011.920851] extcon-disp-state external-connection:disp-state: cable 51 state 1
[ 1011.920856] Extcon HDMI: HPD enabled
[ 1011.920923] tegradc 15210000.nvdisplay: hdmi: plugged
[ 1011.939048] tegradc 15210000.nvdisplay: unblank
[ 2078.951827] tegradc 15210000.nvdisplay: blank - powerdown
[ 2079.006295] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 2079.006301] Extcon AUX1(HDMI) disable
[ 2079.027910] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[ 2079.027995] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 2079.028502] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 2079.597200] extcon-disp-state external-connection:disp-state: cable 51 state 0
[ 2079.597218] Extcon HDMI: HPD disabled
[ 2079.597351] tegradc 15210000.nvdisplay: hdmi: unplugged
[ 2079.613516] tegradc 15210000.nvdisplay: blank - powerdown
[ 2079.613536] tegradc 15210000.nvdisplay: unblank
[ 2079.613550] tegradc 15210000.nvdisplay: unblank
[ 2081.242365] tegradc 15210000.nvdisplay: blank - powerdown
[ 2081.242454] tegradc 15210000.nvdisplay: unblank
[ 2081.243743] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 2081.243997] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 2081.244187] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 2081.249743] Parent Clock set for DC plld2
[ 2081.254673] tegradc 15210000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 2081.256186] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[ 2081.292230] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 2081.292239] Extcon AUX1(HDMI) enable
[ 2081.292456] extcon-disp-state external-connection:disp-state: cable 51 state 1
[ 2081.292460] Extcon HDMI: HPD enabled
[ 2081.292537] tegradc 15210000.nvdisplay: hdmi: plugged
[ 2081.300650] tegradc 15210000.nvdisplay: unblank
[ 2081.320295] tegradc 15210000.nvdisplay: unblank
[ 2222.055895] tegra-xusb 3530000.xhci: port 1 over-current detected
[ 2222.062276] tegra-xusb-padctl 3520000.xusb_padctl: tegra186_phy_xusb_handle_overcurrent: clear port 1 pin 1 OC
[ 2222.382896] usb 2-1: USB disconnect, device number 2
[ 2222.385592] usb usb2: usb_suspend_both: status 0
[ 2232.745499] tegra-xusb 3530000.xhci: port 1 over-current detected
[ 2232.751891] tegra-xusb-padctl 3520000.xusb_padctl: tegra186_phy_xusb_handle_overcurrent: clear port 1 pin 1 OC
[ 2233.175332] usb usb2: usb_suspend_both: status 0
[ 2436.617954] extcon-gpio-states external-connection:extcon@1: Cable state:0, cable id:0
[ 2455.743300] tegra-xusb 3530000.xhci: port 1 over-current detected
[ 2455.749643] tegra-xusb-padctl 3520000.xusb_padctl: tegra186_phy_xusb_handle_overcurrent: clear port 1 pin 1 OC
[ 2456.173927] usb usb2: usb_suspend_both: status 0
[ 5036.721728] FAN rising trip_level:1 cur_temp:51000 trip_temps[2]:61000
[ 5166.688446] nvgpu: 17000000.gp10b railgate_enable_store:297 [INFO] railgate is disabled.
[ 5176.506688] nvgpu: 17000000.gp10b railgate_enable_store:297 [INFO] railgate is disabled.
[ 5451.294082] extcon-gpio-states external-connection:extcon@1: Cable state:0, cable id:0
[ 5456.778120] extcon-gpio-states external-connection:extcon@1: Cable state:1, cable id:2
wenjie@awaicamera:~$ dmesg | grep -i usb0
