Hi.
I want to 15220000.nvdisplay to ouput 4k data by default, when 15220000.nvdisplay read edid fail.
please give some advices. thanks!
Generally this could be hardware problem. This issue is only on your custom board, right?
yes, it’s my custom board.
Power up, when I don’t connect the cable of hdmi2.0, the driver only output 720p, But power up. when I connect the cable of hdmi2.0. the driver can ouput 3840x2160.
Is there a way to tell the driver to output 3840x2160P without edid?
like this:
static const char default_720p_edid[256] = {
0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x00,
0x3a, 0xc4, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00,
0x05, 0x1b, 0x01, 0x03, 0x80, 0x59, 0x32, 0x8c,
0x0a, 0xe2, 0xbd, 0xa1, 0x5b, 0x4a, 0x98, 0x24,
0x15, 0x47, 0x4a, 0x20, 0x00, 0x00, 0x01, 0x01,
0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01,
0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x1d,
0x00, 0x72, 0x51, 0xd0, 0x1e, 0x20, 0x6e, 0x28,
0x55, 0x00, 0x75, 0xf2, 0x31, 0x00, 0x00, 0x1e,
0x01, 0x1d, 0x00, 0xbc, 0x52, 0xd0, 0x1e, 0x20,
0xb8, 0x28, 0x55, 0x40, 0x75, 0xf2, 0x31, 0x00,
0x00, 0x1e, 0x00, 0x00, 0x00, 0xfd, 0x00, 0x32,
0x3d, 0x0f, 0x2e, 0x08, 0x00, 0x0a, 0x20, 0x20,
0x20, 0x20, 0x20, 0x20, 0x00, 0x00, 0x00, 0xfc,
0x00, 0x4e, 0x56, 0x49, 0x44, 0x49, 0x41, 0x00,
0x0a, 0x20, 0x20, 0x20, 0x20, 0x20, 0x01, 0xf9,
0x02, 0x03, 0x19, 0x71, 0x46, 0x84, 0x13, 0x05,
0x14, 0x03, 0x12, 0x23, 0x09, 0x07, 0x07, 0x83,
0x01, 0x00, 0x00, 0x65, 0x03, 0x0c, 0x00, 0x10,
0x00, 0x01, 0x1d, 0x80, 0x18, 0x71, 0x1c, 0x16,
0x20, 0x58, 0x2c, 0x25, 0x00, 0x75, 0xf2, 0x31,
0x00, 0x00, 0x9e, 0x01, 0x1d, 0x80, 0xd0, 0x72,
0x1c, 0x16, 0x20, 0x10, 0x2c, 0x25, 0x80, 0x75,
0xf2, 0x31, 0x00, 0x00, 0x9e, 0x8c, 0x0a, 0xd0,
0x8a, 0x20, 0xe0, 0x2d, 0x10, 0x10, 0x3e, 0x96,
0x00, 0x75, 0xf2, 0x31, 0x00, 0x00, 0x18, 0x8c,
0x0a, 0xd0, 0x90, 0x20, 0x40, 0x31, 0x20, 0x0c,
0x40, 0x55, 0x00, 0x75, 0xf2, 0x31, 0x00, 0x00,
0x18, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xca,
thanks!
Are we talking about the “cable” has to support “Hdmi 2.0” to make Jetson able to read EDID?
