I’m using Replicator to randomize kinda complex scenes and one of the requirements is that I need to control the branches leaving the trigger.
I have (this is a simplification, I have a couple hundred nodes):
Randomization C depends of randomization B, which depends on randomization A
Randomization E depends on randomization D, and D depends on nothing.
An ideal graph would look like this:
trigger
|- Node A → Node B → Node C
|- Node D → Node E
I’ve tried many methods, and I always end up with combinations that make no sense at all, or with the trigger connected to many more nodes.
What’s the correct way of ensuring this behavior? Should I make the connections manually? And if so, what’s the recommended way? (I’ve tried calling _disconnect, acquiring _get_last_exec_attr and then auto_connect and it always connects against the trigger directly.
I’ve also tried using sequential(), but it didn’t solve my problem either. And I think it gets worse when you need to connect against a previous pose() since it uses sequential() (that seems to get the execution pointer back to the trigger if I understood the code correctly) AND it goes against the rules of a ReplicatorItem, it does not return a node!
Hi @christianbarcelo In this scenario, I would investigate the ways isaacsim is using step async and hybridizing the use of replicator graphs depending on various scenarios.
Nice demo! I assume this came with the latest version, I don’t remember seeing it before.
So either hybridizing, or if I can’t (because I’m in the middle of a project that’s already structured classic way) I should be able to put all the randomization together in a custom node (from a custom extension) and just trigger all that in order using USD/Omni APIs.
A question following that example, is it possible to use the async API when running standalone (instantiating a SimulationApp)?
Thanks for the help! Even tho it’s not exactly what I needed, helped me wrap my head around the issue/solution, I appreciate it.
Yeah, I have most of my randomization already done using Replicator’s API, but I can do what you suggest from inside a custom node and wrap it with Replicator.
All the async function have sync versions as well, take a look at this example which includes the same script as standalone and as a script editor (async version):
