How to mangle names with Fortran preprocessor?
Hi all,
I need to add a prefix to names by using preprocessor. The idea is best expressed thus:
#define PREFIX_  ns1_   /*<< this definition comes from outside */
#define MANGLE(name) CONCAT(EXPAND(PREFIX_),name)
#define EXPAND(a) a
#define CONCAT(a,b)  CONCAt(a,b)
#define CONCAt(a,b)  a/**/b      /*<<note: operator ## not supported */
      call MANGLE(foo)  /*<<fortran should see: call ns1_foo */
This code works with nearly all preprocessors, but iIt does not work with PGI internal preprocessor (produces “call PREFIX_foo”). Is there a way to do what I need with PGI Fortran preprocessor or the only option is to preprocess the file with a separate pass?
Preprocessing: pgf90 -Mpreprocess -E x.F
Dima
Hi Dima,
I have filed this issue with our developers as TPR #20531.
In the meantime, you can work around this issue by preprocessing the file using a separate pass with cpp.
Best regards,
+chris
