I have pixel data in a one dimensional array:
R(red value of 0,0 pixel) G(green value of 0,0 pixel) B RG (green value of 0,1 pixel) B RGB RGB …
from the 3 channel image with with = WIDTH and height = HEIGHT
to get blue pixel value at x,y coordinates you do:
channel = 2
pixel_value = array[ (y * WIDTH + x )*3 + channel]
i am trying to map this data on a 3d array of the dimensions:
WIDTHxHEIGHTxCHANNELS so that 3darr[x,z,2] returns same result as above.
Here is what i tryed already. Unfortunatly it does not seem to map properly:
//h_data is the image data
//preparing to fill 3darray with image data and doing it
cudaMemcpy3DParms cpy_params = {0};
cpy_params.extent = ca_extent;
cpy_params.kind = cudaMemcpyHostToDevice;
cpy_params.dstArray = ca_image;
cpy_params.srcPtr = make_cudaPitchedPtr( (void*)h_data, width*sizeof(unsigned char), height, 3 );
CUDA_SAFE_CALL( cudaMemcpy3D( &cpy_params));
I am using cuda2.0beta sdk.
Can someone suggest me what am i doing wrong?
