Hi @pekka.varis Dane made a json for Reallusion Character wrx_xform_reallusion.json (2.1 KB)
I didn’t try this personally, but maybe it will give you some hint?
I attempted to get this working but couldn’t locate the wrnch folder - not even sure where omniverse app is. It doesn’t appear in my Program Files or Program Files x86.
I found {drive}(user)\Documents\Kit\apps\machinima.splash - however wrnch is not listed under the extensions even though I’ve used it before. If this is going to be made easy in a few weeks I’ll wait, but if someone can post a tutorial that’d be sweet.
I am trying to find a floor so I can continue to stream the wrnch data to Omniverse… Thank god it can scan my skeleton anyway :P
I just asked from wrnch support what can I do to help it find the floor. Maybe our bedroom is just too small for it and I have to test this at livingroom :P
I know this is not solution to your problem but I want to inform that I am coming closer to this issue now, as Wrnch support just told me: The floor markers that you are using are not the ones that are bundle with wrEngine. Please use the floor markers found under:
