I want to measure the performance of the GPU in NVIDIA’s GeForce 9400 GT
The steps in the host code are:
clSetKernelArg
clCreateCommandQueue
*start measure
clEnqueueNDRangeKernel
clEnqueueReadBuffer
*end measure
In order to compare I did the same calucation on the host without GPU.
It seems that even when the kernel does nothing, the GPU works 5 times faster than the host.
This does not make sense. It should work much faster. The NVIDIA has 16 cores each running at 1.4GHz. The host is Core2Duo running at 3GHz.
What is wrong in my measurment ?
Thanks,
Zvika
