There is any method to measure a part of code inside kernel?
clock()
clock()
The only thing to do is
void mykenrel(...)
start = clock();
for()
end = clock();
time = end - start;
The clock is time or cycle of gpu? If it is cycles how can I take time?
void mykenrel(...)
start = clock();
for()
end = clock();
time = end - start;
If core clock cycles (half of the shader clock).
The deviceQuery print Clock rate = 1.9Ghz. I must divide with this rate? Also this rate is from a processor of my 128 or the rate for all processor together?
I understand that all thread in one block do the same number of clocks but how can I take time from clocks?
Interested as well
