How to messure actual nvv4l2decoder0 latancy?
• Hardware Platform (Jetson / GPU) nvidia 2070 with maxq design
• DeepStream Version 6.2
• TensorRT Version
I used two sinks to run a deepstream pipeline, one saves the video input as an output video, the other gives a osd output, when I enable the export NVDS_ENABLE_COMPONENT_LATENCY_MEASUREMENT=1 and export NVDS_ENABLE_LATENCY_MEASUREMENT=1, the outputs are completely different. One is :BATCH-NUM = 4512**
Batch meta not found for buffer 0x7fc2b80d6240Encode Latency = 1.504883
and the other is
BATCH-NUM = 126**
Comp name = nvv4l2decoder0 in_system_timestamp = 1689017885691.079102 out_system_timestamp = 1689017885757.385010 component latency= 66.305908
Comp name = nvstreammux-src_bin_muxer source_id = 0 pad_index = 0 frame_num = 126 in_system_timestamp = 1689017885757.476074 out_system_timestamp = 1689017885825.273926 component_latency = 67.797852
Comp name = primary_gie in_system_timestamp = 1689017885825.395996 out_system_timestamp = 1689017885858.065918 component latency= 32.669922
Comp name = tracking_tracker in_system_timestamp = 1689017885858.086914 out_system_timestamp = 1689017885859.565918 component latency= 1.479004
Comp name = tiled_display_tiler in_system_timestamp = 1689017886078.507080 out_system_timestamp = 1689017886090.373047 component latency= 11.865967
Comp name = osd_conv in_system_timestamp = 1689017886344.568115 out_system_timestamp = 1689017886344.916016 component latency= 0.347900
Comp name = nvosd0 in_system_timestamp = 1689017886345.031006 out_system_timestamp = 1689017886360.415039 component latency= 15.384033
Source id = 0 Frame_num = 126 Frame latency = 853.768799 (ms)
and the nvv4l2decoder0 latency on average is 66ms which is unreasonably high. And for the video output, the perf(fps) is 130 which is 7ms per frame. What does these mean and how can we measure nvv4l2decoder0 latency directly?
here’s the config txt
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=1
rows=2
columns=2
width=832
height=832
gpu-id=0
#(0): nvbuf-mem-default - Default memory allocated, specific to particular platform
#(1): nvbuf-mem-cuda-pinned - Allocate Pinned/Host cuda memory, applicable for Tesla
#(2): nvbuf-mem-cuda-device - Allocate Device cuda memory, applicable for Tesla
#(3): nvbuf-mem-cuda-unified - Allocate Unified cuda memory, applicable for Tesla
#(4): nvbuf-mem-surface-array - Allocate Surface Array memory, applicable for Jetson
nvbuf-memory-type=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=3
uri=file:///home/bo/Downloads/outputvideo_303_transformed.mp4
num-sources=1
#drop-frame-interval=2
gpu-id=0
(0): memtype_device - Memory type Device
(1): memtype_pinned - Memory type Host Pinned
(2): memtype_unified - Memory type Unified
cudadec-memtype=0
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink/nv3dsink (Jetson only) 3=File
type=2
sync=1
source-id=0
gpu-id=0
nvbuf-memory-type=0
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265
codec=1
encoder type 0=Hardware 1=Software
enc-type=0
sync=0
#iframeinterval=10
bitrate=2000000
#H264 Profile - 0=Baseline 2=Main 4=High
#H265 Profile - 0=Main 1=Main10
profile=0
output-file=out.mp4
source-id=0
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=0
buffer-pool-size=1
batch-size=1
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
Set muxer output width and height
width=832
height=832
#enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
If set to TRUE, system timestamp will be attached as ntp timestamp
If set to FALSE, ntp timestamp from rtspsrc, if available, will be attached
attach-sys-ts-as-ntp=1
config-file property is mandatory for any gie section.
Other properties are optional and if set will override the properties set in
the infer config file.
[primary-gie]
enable=1
gpu-id=0
model-engine-file=…/…/models/Primary_Detector/resnet10.caffemodel_b4_gpu0_int8.engine
batch-size=4
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=0
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primary.txt
[tracker]
enable=1
For NvDCF and NvDeepSORT tracker, tracker-width and tracker-height must be a multiple of 32, respectively
tracker-width=640
tracker-height=384
ll-lib-file=/opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
ll-config-file required to set different tracker types
ll-config-file=config_tracker_IOU.yml
ll-config-file=config_tracker_NvSORT.yml
ll-config-file=config_tracker_NvDCF_perf.yml
ll-config-file=config_tracker_NvDCF_accuracy.yml
ll-config-file=config_tracker_NvDeepSORT.yml
gpu-id=0
enable-batch-process=1
enable-past-frame=1
display-tracking-id=1
[secondary-gie0]
enable=0
model-engine-file=…/…/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine
gpu-id=0
batch-size=16
gie-unique-id=4
operate-on-gie-id=1
operate-on-class-ids=0;
config-file=config_infer_secondary_vehicletypes.txt
[secondary-gie1]
enable=0
model-engine-file=…/…/models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_int8.engine
batch-size=16
gpu-id=0
gie-unique-id=5
operate-on-gie-id=1
config-file=config_infer_secondary_carcolor.txt
[secondary-gie2]
enable=0
model-engine-file=…/…/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine
batch-size=16
gpu-id=0
gie-unique-id=6
operate-on-gie-id=1
config-file=config_infer_secondary_carmake.txt
[tests]
file-loop=0
There are some problems in your config file. You can set [sink0],[sink1]… instead of two same [sink0].
You can just attach the txt file and outputvideo_303_transformed.mp4 as a attachment.
o sry, I didn’t use the first sink, pasted there by mistake. with one sink the issues are still there
OK. The latency here is just for 1 frame and the fps is an average value. So the value of latency may have jitter.
yeah, so I wrote a script to process the output of the measurement and the average latency for nvv4l2decoder0 component is still 66ms. Which is not suppose to be this high since if I’m trying to get a video output the fps performance is 150 fps.
Could you attach your original log? Below are the results from my end:
PTS
**PERF: FPS 0 (Avg)
**PERF: 0.00 (0.00)
**PERF: 0.00 (0.00)
**PERF: 295.10 (287.50)
**PERF: 233.39 (250.36)
**PERF: 115.94 (197.39)
**PERF: 112.09 (172.43)
**PERF: 120.14 (160.78)
**PERF: 119.86 (153.35)
**PERF: 119.95 (148.20)
**PERF: 119.93 (144.44)
**PERF: 111.11 (140.50)
**PERF: 119.85 (138.34)
**PERF: 119.92 (136.58)
v4l2 latency
component latency= 0.238770
component latency= 2.058105
component latency= 3.152100
component latency= 1.996094
component latency= 1.995117
component latency= 1354.277100
component latency= 0.310059
component latency= 0.008057
component latency= 0.137207
component latency= 2.328125
component latency= 10.677979
component latency= 0.144043
component latency= 0.177002
component latency= 0.201172
component latency= 11.682129
component latency= 0.040039
component latency= 1.471924
component latency= 1.305908
component latency= 9.652832
component latency= 0.940918
component latency= 1.357910
component latency= 0.111084
component latency= 9.866943
component latency= 0.110107
component latency= 0.841064
component latency= 1.495117
component latency= 9.775879
component latency= 0.937988
component latency= 1.348145
component latency= 10.800049
component latency= 0.168945
component latency= 0.862061
component latency= 1.401855
component latency= 15.879883
component latency= 1.270996
component latency= 1.674072
component latency= 0.341064
component latency= 11.329102
component latency= 0.956055
component latency= 1.498047
component latency= 10.989990
component latency= 0.113037
component latency= 0.998047
component latency= 1.648926
component latency= 10.697998
component latency= 0.125977
component latency= 0.909912
component latency= 1.546875
component latency= 11.383057
component latency= 0.141113
component latency= 0.866943
component latency= 1.487061
component latency= 11.657959
component latency= 0.190918
component latency= 0.939941
component latency= 1.510986
component latency= 11.081055
component latency= 0.243164
component latency= 0.887939
component latency= 1.582031
component latency= 11.661133
component latency= 1.125000
component latency= 1.518066
component latency= 0.467041
component latency= 10.274170
component latency= 0.105957
component latency= 0.157959
component latency= 12.100098
component latency= 0.171143
component latency= 0.960205
component latency= 1.637939
component latency= 11.192139
component latency= 1.147949
component latency= 1.524902
component latency= 0.065186
component latency= 12.062012
component latency= 0.827881
component latency= 1.465088
component latency= 5.177979
component latency= 5.448975
component latency= 0.041992
component latency= 1.049072
component latency= 3.783936
component latency= 9.055908
component latency= 0.217041
component latency= 1.023926
component latency= 1.738037
component latency= 9.188965
component latency= 1.000977
component latency= 1.685059
component latency= 9.606934
component latency= 0.147949
component latency= 2.568115
component latency= 0.102051
component latency= 9.812012
component latency= 0.123047
component latency= 1.167969
component latency= 1.795898
component latency= 10.170166
component latency= 0.101074
component latency= 0.082031
component latency= 7.146973
component latency= 5.921143
component latency= 0.052002
component latency= 2.728027
component latency= 0.069092
component latency= 10.075928
component latency= 0.127930
component latency= 1.014893
component latency= 1.882080
component latency= 9.971191
component latency= 1.138184
component latency= 1.676025
component latency= 4.578857
component latency= 6.243896
component latency= 0.081055
component latency= 1.153809
component latency= 10.410889
component latency= 0.065918
component latency= 1.132080
component latency= 1.760986
component latency= 9.960938
component latency= 0.074951
component latency= 1.729980
component latency= 10.185059
component latency= 1.241943
component latency= 1.868896
component latency= 10.417969
component latency= 0.089844
component latency= 1.351074
component latency= 1.896973
component latency= 10.519043
component latency= 0.138184
component latency= 1.310791
component latency= 1.895020
component latency= 10.780029
component latency= 3.111816
component latency= 0.012939
component latency= 10.604980
component latency= 0.172119
component latency= 3.027100
component latency= 0.174072
component latency= 10.034912
component latency= 0.099854
component latency= 3.079102
component latency= 0.076172
component latency= 10.701904
component latency= 0.162842
component latency= 3.009033
component latency= 11.139893
component latency= 0.135010
component latency= 1.274170
component latency= 1.972168
component latency= 10.625000
component latency= 3.205078
component latency= 10.360107
component latency= 0.154053
component latency= 1.356201
component latency= 1.922119
component latency= 10.720947
component latency= 0.085205
component latency= 2.015869
component latency= 10.290039
component latency= 0.139160
component latency= 1.293945
component latency= 1.908936
component latency= 10.059814
component latency= 0.070068
component latency= 1.397949
component latency= 1.905029
component latency= 10.724854
component latency= 0.108887
component latency= 1.485840
component latency= 1.926025
component latency= 10.436035
component latency= 1.333008
component latency= 1.979980
component latency= 10.854980
component latency= 1.332031
component latency= 1.978027
component latency= 10.641113
component latency= 0.136963
component latency= 1.395996
component latency= 1.876953
component latency= 10.380127
component latency= 3.395020
component latency= 0.396973
component latency= 10.912109
component latency= 0.051025
component latency= 1.355957
component latency= 2.112061
component latency= 11.059082
component latency= 0.260986
component latency= 1.211914
component latency= 12.614014
component latency= 0.146973
component latency= 3.022949
component latency= 12.116943
component latency= 0.251953
component latency= 1.146973
component latency= 1.735107
component latency= 11.466064
component latency= 0.170898
component latency= 1.158936
component latency= 1.640869
component latency= 9.599854
component latency= 0.011963
component latency= 1.198975
component latency= 1.833984
component latency= 10.352051
component latency= 1.039062
component latency= 1.609131
component latency= 0.058105
component latency= 10.196045
component latency= 0.269043
component latency= 0.133057
component latency= 1.156006
component latency= 11.604980
component latency= 0.109131
component latency= 1.180176
component latency= 1.869873
component latency= 10.502197
component latency= 0.106934
component latency= 1.121094
component latency= 2.159180
component latency= 10.172119
component latency= 0.059814
component latency= 3.083984
component latency= 0.077148
component latency= 10.835938
component latency= 1.434082
component latency= 3.342041
component latency= 3.543213
component latency= 10.579102
component latency= 0.122070
component latency= 1.982910
component latency= 9.819824
component latency= 1.766113
component latency= 8.959961
component latency= 0.145020
component latency= 1.152832
component latency= 1.658936
component latency= 9.637939
component latency= 0.140869
component latency= 2.647949
component latency= 9.687012
component latency= 0.149170
component latency= 2.611816
component latency= 0.229004
component latency= 10.709961
component latency= 0.180176
component latency= 1.110107
component latency= 1.755859
component latency= 10.500000
component latency= 0.112061
component latency= 2.797119
component latency= 0.114990
component latency= 10.244141
component latency= 0.098145
component latency= 1.100098
component latency= 2.080078
component latency= 10.281982
component latency= 0.107910
component latency= 2.607910
component latency= 0.024170
component latency= 10.938965
component latency= 0.151123
component latency= 1.157959
component latency= 1.724121
component latency= 10.687988
component latency= 0.166016
component latency= 0.992920
component latency= 3.334961
component latency= 8.155029
component latency= 0.119141
component latency= 1.018066
component latency= 1.700928
component latency= 9.143066
component latency= 0.118896
component latency= 2.729004
component latency= 10.608887
component latency= 1.153076
component latency= 1.587891
component latency= 0.175781
component latency= 10.572021
component latency= 1.072998
component latency= 1.588867
component latency= 0.067871
component latency= 10.554932
component latency= 0.066162
component latency= 4.417969
component latency= 8.114990
component latency= 0.218018
component latency= 9.614990
component latency= 0.117188
component latency= 1.321045
component latency= 12.704102
component latency= 0.053955
component latency= 0.163086
component latency= 4.492920
component latency= 7.114014
component latency= 0.138916
component latency= 0.085938
component latency= 2.956055
component latency= 7.773926
component latency= 0.093018
component latency= 1.569824
component latency= 0.068115
component latency= 13.585205
component latency= 0.156006
component latency= 0.092041
component latency= 26.715088
component latency= 0.219238
component latency= 1.398926
component latency= 31.367920
component latency= 0.121094
component latency= 4.314941
component latency= 28.556152
component latency= 0.180908
component latency= 0.077881
component latency= 0.114014
component latency= 32.386963
component latency= 0.177979
component latency= 1.342041
component latency= 31.481934
component latency= 0.139893
component latency= 1.418945
component latency= 30.782959
component latency= 0.120117
component latency= 32.675049
component latency= 0.183105
component latency= 0.135986
component latency= 32.377930
component latency= 0.153076
component latency= 0.102783
component latency= 0.111816
component latency= 32.802002
component latency= 0.042969
component latency= 0.140137
component latency= 2.808105
component latency= 30.489990
component latency= 0.153809
component latency= 0.247070
component latency= 32.637939
component latency= 0.246826
component latency= 1.335938
component latency= 31.239990
component latency= 0.198975
component latency= 1.725098
component latency= 30.944824
component latency= 0.274902
component latency= 0.132080
component latency= 32.271973
component latency= 1.226807
component latency= 31.506836
component latency= 0.062988
component latency= 1.562012
component latency= 0.044922
component latency= 31.149170
component latency= 33.066162
component latency= 0.147217
component latency= 2.024170
component latency= 30.222900
component latency= 0.161865
component latency= 4.312012
component latency= 28.393066
component latency= 0.151855
component latency= 0.175049
component latency= 0.197998
component latency= 32.385986
component latency= 0.124023
component latency= 0.181885
component latency= 0.309082
component latency= 32.313965
component latency= 0.159912
component latency= 0.095947
component latency= 0.188965
component latency= 32.983154
component latency= 0.109863
component latency= 0.325928
component latency= 32.227051
component latency= 0.090088
component latency= 0.079102
component latency= 32.783936
component latency= 0.193115
component latency= 2.739990
component latency= 27.804932
component latency= 2.006836
component latency= 0.134766
component latency= 30.398926
component latency= 1.614990
component latency= 2.980957
component latency= 30.043213
component latency= 0.128174
component latency= 0.323975
component latency= 32.697998
component latency= 0.057129
component latency= 2.959961
component latency= 30.346924
component latency= 0.090820
component latency= 0.072021
component latency= 32.616943
component latency= 0.072998
component latency= 0.057861
component latency= 4.616943
component latency= 27.775879
component latency= 0.094971
component latency= 1.494141
component latency= 0.128906
component latency= 31.079102
component latency= 0.060791
component latency= 33.139893
component latency= 0.176025
component latency= 1.469971
component latency= 31.087158
component latency= 0.279053
component latency= 0.050049
component latency= 32.839111
component latency= 0.015869
component latency= 0.118164
component latency= 4.503906
component latency= 35.025879
component latency= 0.028076
component latency= 0.086914
component latency= 3.376953
component latency= 33.864990
component latency= 33.992920
component latency= 0.088867
component latency= 3.405029
component latency= 51.955811
component latency= 0.646973
component latency= 0.241943
component latency= 3.291992
component latency= 42.165039
component latency= 0.087891
component latency= 3.329102
component latency= 0.091064
component latency= 14.916992
component latency= 32.306152
component latency= 0.466797
component latency= 0.558838
component latency= 0.729980
component latency= 45.887939
component latency= 0.239990
component latency= 18.594971
component latency= 42.043945
component latency= 0.020020
component latency= 0.049072
component latency= 23.944824
component latency= 33.570801
component latency= 0.786133
component latency= 31.927002
component latency= 0.916016
component latency= 31.773926
component latency= 0.137939
component latency= 0.388916
component latency= 32.322021
component latency= 0.163818
component latency= 0.160156
component latency= 1.361084
component latency= 31.504883
component latency= 0.206055
component latency= 0.150879
component latency= 1.368164
component latency= 31.476074
component latency= 0.191162
component latency= 0.273193
component latency= 0.895996
component latency= 31.952881
component latency= 0.872070
component latency= 31.776855
component latency= 0.009033
component latency= 4.088867
component latency= 0.031006
component latency= 28.935059
component latency= 0.096191
component latency= 0.224121
component latency= 32.662842
component latency= 0.142822
component latency= 0.219971
component latency= 32.739990
component latency= 0.068848
component latency= 4.235107
component latency= 28.229004
component latency= 0.131104
component latency= 0.700195
component latency= 32.312988
component latency= 0.078857
component latency= 0.108154
component latency= 6.791992
component latency= 26.158936
component latency= 4.373047
component latency= 28.429932
component latency= 3.871826
component latency= 28.348145
component latency= 0.034912
component latency= 4.507080
component latency= 28.270996
component latency= 2.312988
component latency= 0.054932
component latency= 30.428955
component latency= 0.205078
component latency= 2.079102
component latency= 30.761963
component latency= 0.056152
component latency= 0.104980
component latency= 4.518066
component latency= 28.182861
component latency= 0.075928
component latency= 2.308105
component latency= 30.463867
component latency= 0.939209
component latency= 31.822998
component latency= 0.104004
component latency= 32.185059
component latency= 6.771973
component latency= 25.705078
component latency= 0.083984
component latency= 2.237061
component latency= 0.097168
component latency= 30.437988
component latency= 0.775879
component latency= 0.097900
component latency= 31.829102
component latency= 6.990967
component latency= 26.053955
component latency= 2.338867
component latency= 30.507080
component latency= 0.126953
component latency= 0.375000
component latency= 32.687988
component latency= 4.551025
component latency= 28.479980
component latency= 0.213135
component latency= 32.568848
component latency= 0.143066
component latency= 4.650879
component latency= 27.831055
component latency= 0.254883
component latency= 0.942871
component latency= 31.770996
component latency= 0.184814
component latency= 7.104980
component latency= 25.618896
component latency= 0.038818
component latency= 4.973145
component latency= 27.763916
component latency= 0.041016
component latency= 2.472168
component latency= 0.060059
component latency= 30.508789
component latency= 0.073975
component latency= 0.165039
component latency= 2.314209
component latency= 30.381104
component latency= 0.173828
component latency= 0.235840
component latency= 32.468994
component latency= 1.027832
component latency= 31.596924
component latency= 0.159180
component latency= 1.122070
component latency= 31.693848
component latency= 32.380127
component latency= 0.083008
component latency= 7.368164
component latency= 25.468018
component latency= 2.479980
component latency= 30.659180
component latency= 0.095215
component latency= 32.486816
component latency= 0.134033
component latency= 7.322998
component latency= 25.463867
component latency= 5.095947
component latency= 27.488037
component latency= 0.066895
component latency= 5.077881
component latency= 27.963867
component latency= 0.100830
component latency= 5.083008
component latency= 27.540039
component latency= 2.483154
component latency= 30.395996
component latency= 0.201904
component latency= 2.158936
component latency= 30.581055
component latency= 0.178955
component latency= 0.275879
component latency= 31.688965
component latency= 0.242920
component latency= 0.204102
component latency= 2.089844
component latency= 30.108154
component latency= 0.179932
component latency= 0.199951
component latency= 32.664062
component latency= 0.239014
component latency= 32.777832
component latency= 0.164062
component latency= 0.196045
component latency= 0.188232
component latency= 32.667969
component latency= 0.166992
component latency= 0.971924
component latency= 32.460938
component latency= 0.302979
component latency= 31.912109
component latency= 0.947021
component latency= 31.895020
component latency= 0.196777
component latency= 32.344971
component latency= 0.233887
component latency= 1.048828
component latency= 31.401123
component latency= 0.227783
component latency= 1.182861
component latency= 0.627197
component latency= 31.101074
component latency= 0.225098
component latency= 0.256836
component latency= 32.541016
component latency= 5.138184
component latency= 26.906982
component latency= 0.158936
component latency= 33.070068
component latency= 0.148926
component latency= 0.098877
component latency= 0.231934
component latency= 32.251953
component latency= 0.298096
component latency= 32.512939
component latency= 0.155029
component latency= 30.021973
component latency= 1.819092
component latency= 0.048828
component latency= 32.979980
component latency= 0.029053
component latency= 4.810059
component latency= 27.858154
component latency= 0.063965
component latency= 5.068115
component latency= 28.173096
component latency= 2.535156
component latency= 0.096924
component latency= 30.365967
component latency= 0.129883
component latency= 0.308105
component latency= 2.076904
component latency= 30.531006
component latency= 30.734131
component latency= 0.145996
component latency= 32.479980
component latency= 0.336914
component latency= 32.414062
component latency= 0.192871
component latency= 0.278076
component latency= 0.888916
component latency= 32.197998
component latency= 0.230957
component latency= 1.239014
component latency= 31.927979
component latency= 4.945068
component latency= 26.211914
component latency= 2.352051
component latency= 30.630127
component latency= 0.684082
component latency= 32.238037
component latency= 4.678955
component latency= 27.993896
component latency= 32.867920
component latency= 0.130859
component latency= 0.130127
component latency= 7.437012
component latency= 25.559082
component latency= 1.162842
component latency= 30.610107
component latency= 0.369141
component latency= 32.119873
component latency= 0.119873
component latency= 0.162109
component latency= 0.290039
component latency= 32.208984
component latency= 0.850098
component latency= 0.183838
component latency= 32.300049
component latency= 0.076904
component latency= 0.285156
component latency= 2.209961
component latency= 30.734863
component latency= 0.067139
component latency= 1.012939
component latency= 1.537842
component latency= 31.075928
component latency= 0.304199
component latency= 2.137939
component latency= 29.898926
component latency= 0.156982
component latency= 0.115967
component latency= 32.203857
component latency= 0.278809
component latency= 4.716064
component latency= 27.946045
component latency= 2.240967
component latency= 30.573975
component latency= 2.215088
component latency= 30.539795
component latency= 0.197021
component latency= 0.419922
component latency= 32.197021
component latency= 0.117920
component latency= 0.116943
component latency= 7.302979
component latency= 25.640869
component latency= 25.813965
component latency= 2.450928
component latency= 30.229004
component latency= 30.346191
component latency= 2.214844
component latency= 29.864990
component latency= 0.006104
component latency= 0.718994
component latency= 31.833008
component latency= 0.189209
component latency= 2.160156
component latency= 30.693115
component latency= 0.237061
component latency= 1.101074
component latency= 32.244873
component latency= 1.155029
component latency= 31.132080
component latency= 0.224854
component latency= 0.142090
component latency= 0.358154
component latency= 32.177002
component latency= 0.295898
component latency= 32.585205
component latency= 0.103027
component latency= 32.605957
component latency= 0.270996
component latency= 0.125000
component latency= 32.685059
component latency= 7.445801
component latency= 25.216064
component latency= 0.099121
component latency= 2.579102
component latency= 29.832031
component latency= 0.276855
component latency= 2.207031
component latency= 30.529053
component latency= 5.201904
component latency= 27.560059
component latency= 0.005859
component latency= 0.221924
component latency= 1.392822
component latency= 31.166016
component latency= 0.122803
component latency= 33.018066
component latency= 5.224854
component latency= 26.856934
component latency= 1.036865
component latency= 31.638916
component latency= 0.207031
component latency= 0.933838
component latency= 31.609131
component latency= 0.301025
component latency= 2.143066
component latency= 30.671143
component latency= 0.107178
component latency= 33.010010
component latency= 0.081787
component latency= 32.322998
component latency= 32.469971
component latency= 2.468018
component latency= 30.444092
component latency= 0.043213
component latency= 33.184082
component latency= 7.568115
component latency= 25.266113
component latency= 0.069824
component latency= 2.277100
component latency= 1.002930
component latency= 29.866943
component latency= 3.778809
component latency= 3.015137
component latency= 25.802979
component latency= 2.644043
component latency= 0.055176
component latency= 30.235107
component latency= 5.205811
component latency= 27.500000
component latency= 2.495850
component latency= 30.661133
component latency= 0.045898
component latency= 2.248047
component latency= 30.033936
component latency= 1.016113
component latency= 31.636963
component latency= 0.088135
component latency= 32.524902
component latency= 0.150146
component latency= 0.343018
component latency= 32.472900
component latency= 0.395020
component latency= 32.735840
component latency= 0.038086
component latency= 5.036865
component latency= 28.328125
component latency= 0.850830
component latency= 31.473877
component latency= 0.080078
component latency= 7.514893
component latency= 25.238037
component latency= 0.039062
component latency= 0.078125
component latency= 5.309082
component latency= 32.236084
component latency= 0.013184
component latency= 2.541992
component latency= 25.437012
component latency= 0.031982
component latency= 2.372070
component latency= 30.629883
component latency= 2.542969
component latency= 0.064209
component latency= 30.164062
component latency= 32.695801
component latency= 0.046143
component latency= 7.730957
component latency= 25.031982
component latency= 2.585205
component latency= 30.302002
component latency= 32.447021
component latency= 0.032959
component latency= 2.406006
component latency= 30.798828
component latency= 0.181152
component latency= 2.360840
component latency= 30.106934
component latency= 5.308105
component latency= 27.727051
component latency= 2.480957
component latency= 29.989014
component latency= 0.328857
component latency= 32.668945
component latency= 0.211914
component latency= 4.958008
component latency= 28.196045
component latency= 0.234863
component latency= 42.815918
component latency= 20.900879
component latency= 33.000977
component latency= 0.213867
component latency= 43.291992
component latency= 21.892090
component latency= 49.598877
component latency= 0.238037
component latency= 0.240967
component latency= 16.119873
component latency= 33.458008
component latency= 0.719971
component latency= 37.365967
component latency= 7.583984
component latency= 20.469971
component latency= 2.625977
component latency= 0.262939
component latency= 30.110840
component latency= 2.632812
component latency= 30.688965
component latency= 0.093994
component latency= 0.214844
component latency= 2.428955
component latency= 30.313232
component latency= 0.141846
component latency= 32.921875
component latency= 7.443848
component latency= 24.908936
component latency= 2.543945
component latency= 30.371826
component latency= 2.421875
component latency= 30.125977
component latency= 0.241211
component latency= 32.324951
component latency= 0.211182
component latency= 32.647217
component latency= 2.351074
component latency= 0.056885
component latency= 2.523926
component latency= 29.983887
component latency= 0.100098
component latency= 32.617920
component latency= 7.413086
component latency= 25.532959
component latency= 2.598145
component latency= 0.039795
component latency= 30.013916
component latency= 32.772949
component latency= 4.729980
component latency= 28.224854
component latency= 0.186035
component latency= 0.169922
component latency= 32.362061
component latency= 0.223877
component latency= 32.456055
component latency= 0.203125
component latency= 0.836914
component latency= 31.896973
component latency= 5.100098
component latency= 27.626953
component latency= 0.244873
component latency= 2.410889
component latency= 30.440918
component latency= 0.864990
component latency= 32.147949
component latency= 0.857178
component latency= 31.645020
component latency= 0.874023
component latency= 31.869141
component latency= 0.037109
component latency= 7.508057
component latency= 25.342041
component latency= 0.062012
component latency= 2.614014
component latency= 30.250000
component latency= 0.046875
component latency= 0.192139
component latency= 2.396973
component latency= 30.708008
component latency= 0.024902
component latency= 0.471191
component latency= 2.752197
component latency= 29.607910
component latency= 0.267822
component latency= 2.099854
component latency= 30.458008
component latency= 5.101074
component latency= 27.712891
component latency= 0.170166
component latency= 32.848145
component latency= 5.218994
component latency= 27.456787
component latency= 0.386963
component latency= 29.995850
component latency= 5.077148
component latency= 0.047119
component latency= 27.967041
component latency= 2.380127
component latency= 30.052979
component latency= 32.759033
component latency= 32.851074
component latency= 0.061035
component latency= 32.700195
component latency= 0.149902
component latency= 0.106201
component latency= 32.558838
component latency= 32.627930
component latency= 0.126221
component latency= 0.236084
component latency= 32.604980
component latency= 0.161133
component latency= 31.962158
component latency= 0.209961
component latency= 32.871826
component latency= 0.121826
component latency= 1.062012
component latency= 31.119141
component latency= 0.189941
component latency= 0.926025
component latency= 31.696045
component latency= 2.322021
component latency= 30.501953
component latency= 7.527100
component latency= 25.093994
component latency= 0.010010
component latency= 2.544189
component latency= 0.101807
component latency= 30.268066
component latency= 0.794189
component latency= 32.077881
component latency= 0.784180
component latency= 31.891846
component latency= 0.027100
component latency= 2.380859
component latency= 30.215088
component latency= 0.035889
component latency= 2.419189
component latency= 30.081055
component latency= 2.362793
component latency= 30.414062
component latency= 2.385010
component latency= 30.438232
component latency= 32.463867
component latency= 0.187988
component latency= 2.253906
component latency= 30.564941
component latency= 32.445068
component latency= 0.288086
component latency= 2.304932
component latency= 30.322021
component latency= 32.721924
component latency= 7.538818
component latency= 25.025146
component latency= 2.365967
component latency= 0.208008
component latency= 30.152100
component latency= 4.928955
component latency= 27.820068
component latency= 35.295898
component latency= 7.470947
component latency= 22.501953
component latency= 0.075195
component latency= 5.156006
component latency= 26.868164
component latency= 5.110840
component latency= 28.092041
component latency= 28.261963
component latency= 5.252930
component latency= 27.843018
component latency= 5.131836
component latency= 27.239990
component latency= 2.635010
component latency= 29.869141
component latency= 0.112793
component latency= 32.541992
component latency= 4.708008
component latency= 27.923096
component latency= 2.374023
component latency= 30.936035
component latency= 32.996094
component latency= 32.611084
component latency= 2.421143
component latency= 30.464111
component latency= 0.317139
component latency= 0.421143
component latency= 33.242920
component latency= 33.810059
The average of the latency is 8ms, the average of the fps is 119. It’s basically matched.
