How to mex this simple .cu file?
This is a very simple cuda file mytest.cu, which is basically a mex interface with cuda code together. All I want is to make it callable to MATLAB
#include "mex.h"
#include <cuda.h>
#include <cuda_runtime.h>
__global__ void test_cuda_vs(int a, int b)
    return;
void mexFunction(int nlhs, mxArray *plhs[],
    int nrhs, const mxArray *prhs[])
        plhs[0] = mxCreateDoubleMatrix(1,1,mxREAL);
        double* out = mxGetPr(plhs[0]);
        test_cuda<<<1,1>>>(1,2);
        return;
How should I compile it to make test_cuda can be called by MATLAB like a built-in function?
I have
system('nvcc -c -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 mytest.cu')
generating the obj file. Should I use mex to do next step? I am not sure how to do that, and what is the command line roughly?
Or it cannot, and I should do it in another way? Thanks
PS: I have
Windows 7 64-bit
CUDA 5.5, 6.0, 6.5
MATLAB 2014
VS2012
[url]http://www.orangeowlsolutions.com/archives/498[/url]
That walks you through the whole process (assuming you are using Visual Studio).
The CUDA code needs to be in a separate .cu file and called via an extern “C” function. You can call cuBLAS,cuFFT or cuSPARSE directly from a mexFunction however.
This is terrific, Thanks!
You can do a two-step process of first having nvcc generate the fatbin and stuff it into a .cpp file, then Matlab’s mex will be happy to compile/link that. Here’s a slightly genericized snippet from one of my Makefiles:
stuff.o: stuff.cu
        nvcc $(NVCC_OPTS) $(NVCC_INCL) $(PAR_INCL) -cuda stuff.cu -o stuff.cpp
        mex $(MEX_OPTS) -c stuff.cpp
stuff: cudaCommon.o stuff.o
        mex $(MEX_OPTS) $(PAR_LDIR) $(PAR_LIBS) -cxx $@.o -o $@ $(MEX_LDIR) $(MEX_LIBS)
I’ve had this complain if cudaCommon.o contains just device rather than device inline functions though, the linker claimed that I had multiple instances of a function definition.
