How to modify if the custom carrier board does not use GPIO to control vdd_3v3_pcie and vdd_12v_pcie?
Is the following modification correct?
Original in Linux_for_Tegra/source/hardware/nvidia/t23x/nv-public/tegra234-p3701-0000.dtsi:
vdd_3v3_pcie: regulator-vdd-3v3-pcie {
compatible = “regulator-fixed”;
regulator-name = “VDD_3V3_PCIE”;
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
gpio = <&gpio TEGRA234_MAIN_GPIO(H, 4) GPIO_ACTIVE_HIGH>;
regulator-boot-on;
enable-active-high;
vdd_12v_pcie: regulator-vdd-12v-pcie {
regulator-name = “VDD_12V_PCIE”;
regulator-min-microvolt = <12000000>;
regulator-max-microvolt = <12000000>;
gpio = <&gpio TEGRA234_MAIN_GPIO(A, 1) GPIO_ACTIVE_LOW>;
regulator-boot-on;
Modified to:
regulator-always-on;
Is this correct?
Hi idealong,
Yes, this is correct if both PCIe rails are always on by hardware. Remove the GPIO control and use fixed regulators with regulator-always-on. If your board does not have 12V PCIe, remove vpcie12v-supply from the PCIe node instead of keeping a dummy regulator.
