In TensorRT-6.0.1.5\samples\sampleUffSSD\config.py I find :
NMS = gs.create_plugin_node(name="NMS", op="NMS_TRT",
shareLocation=1,
varianceEncodedInTarget=0,
backgroundLabelId=0,
confidenceThreshold=1e-8,
nmsThreshold=0.6,
topK=100,
keepTopK=100,
numClasses=91,
inputOrder=[0, 2, 1],
confSigmoid=1,
isNormalized=1)
What I know is that “inputOrder=[0,2,1]” set the input order of NMS Node,each number represent a node of locData\confData\priorData.But how can I get relationship between number and each node? In other way,What is locData’s number?
Specifies the order of inputs {loc_data, conf_data, priorbox_data}.
In other words, inputOrder[0] is for loc_data, inputOrder[1] is for conf_data and inputOrder[2] is for priorbox_data.
For example, if your inputs in the memory are in the order of loc_data, priorbox_data, conf_data, then inputOrder should be [0, 2, 1].
Hi @SunilJB:
Yes,I know inputOrder[0] is for loc_data, inputOrder[1] is for conf_data and inputOrder[2] is for priorbox_data.
But how can I know the order of {loc_data, conf_data, priorbox_data} in my memory? I use coverter-to-uff tool to covert a tf modle to uff. In old uff version, the order of {loc_data, conf_data, priorbox_data} will show in console when converting,but in the newest version UFF tool,it only print input node. And I realized the order of {loc_data, conf_data, priorbox_data} in memory maybe different if I use different UFF tool,though I covert form the same PB model.
In my experiment,UFF tool is in TRT 5.0.4.3 and TRT 6.0.1.5. the order of {loc_data, conf_data, priorbox_data} in my memory is [1,2,0] and [0,2,1].
The order of {loc_data, conf_data, priorbox_data} will be based on the NMS setting in your .pbtxt file:
For example if:
inputs: "concat_box_conf"
inputs: "concat_box_loc"
inputs: "concat_priorbox"
Then {loc_data, conf_data, priorbox_data} will be [1 0 2]
Sorry,I don’t know where to find my .pbtxt file.
Which step uses that file?
Dose it use to frozen .ckpt to .pb?
I find code to covert .pb to .pbtxt.
import tensorflow as tf
from tensorflow.python.platform import gfile
from google.protobuf import text_format
def convert_pb_to_pbtxt(filename):
with gfile.FastGFile(filename,'rb') as f:
graph_def = tf.GraphDef()
graph_def.ParseFromString(f.read())
tf.import_graph_def(graph_def, name='')
tf.train.write_graph(graph_def, './', 'protobuf.pbtxt', as_text=True)
return
def convert_pbtxt_to_pb(filename):
"""Returns a `tf.GraphDef` proto representing the data in the given pbtxt file.
Args:
filename: The name of a file containing a GraphDef pbtxt (text-formatted
`tf.GraphDef` protocol buffer data).
with tf.gfile.FastGFile(filename, 'r') as f:
file_content = f.read()
# Merges the human-readable string in `file_content` into `graph_def`.
text_format.Merge(file_content, graph_def)
tf.train.write_graph( graph_def , './' , 'protobuf.pb' , as_text = False )
I try it today.
