HI everyone,
I want to monidy Orin NVCSI register such as NVCSI_PHY_0_NVCSI_CIL_A_CONTROL_0 register, how to modify it ? I use busybox tool read the register data is 0xFFFFFFFF, the command is
sudo busybox devmem 0x15a11ce8
HI everyone,
Release r35.x was block the NVCSI/VI REG by RTCPU firmware.
Have disable OEM firewall as below.
~/nvidia/nvidia_sdk/JetPack_5.0.2_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/tegra234-firewall-config-base.dtsi
reg@4673 { /* CBB_CENTRAL_CBB_FIREWALL_NVCSI_ENGINE_BLF, READ_CTL */
exclusion-info = <0>;
reg@4674 { /* CBB_CENTRAL_CBB_FIREWALL_NVCSI_ENGINE_BLF, WRITE_CTL */
reg@4675 { /* CBB_CENTRAL_CBB_FIREWALL_NVCSI_ENGINE_BLF, CTL_SETTING */
And re-flash the target to verify.
Thank you for your reply, does only re-flash spi flash or need re-flash emmc? And how to only re-flash spi flash? Thanks.
Have below command to flash the system.
sudo ./flash.sh -r jetson-agx-orin-devkit mmcblk0p1
Please add below context to tegra234-mb2-bct-scr-p3701-0000-override.dts
And reflash the device to verify.
Shall I modify tegra234-mb2-bct-scr-p3701-0000-override.dts and tegra234-firewall-config-base.dtsi together?
Please just add those context to tegra234-mb2-bct-scr-p3701-0000-override.dts only
