Hi Nvidia,
We would like to upgrade jetson nx from 32.7.1 to 35.1 by ota payload package.
There is partition layout change already in our 32.7.1 : flash_l4t_t194_spi_emmc_p3668.xml add two partition between RECROOTFS and UDA as beneth:
<partition name="RECROOTFS" type="data">
<allocation_policy> sequential </allocation_policy>
<filesystem_type> basic </filesystem_type>
<size> RECROOTFSSIZE </size>
<file_system_attribute> 0 </file_system_attribute>
<allocation_attribute> 0x8 </allocation_attribute>
<percent_reserved> 0 </percent_reserved>
<description> **Optional.** Reserved for future use by the recovery filesystem;
removable. </description>
</partition>
<partition name="ADRESERVE" type="data">
<size> 12288 </size>
<description> **Optional.** Reserved for ADLINK use. </description>
</partition>
<partition name="ADRESERVE_b" type="data">
</partition>
<partition name="UDA" type="data">
<size> 18432 </size>
<allocation_attribute> 0x808 </allocation_attribute>
<description> **Required.** Automatically takes all remaining space on the device except that
occupied by the `secondary_gpt` partition. Allocation attribute must be set to 0x808.
May be mounted and used to store user data. </description>
</partition>
in 35.1, we also add these two partition in flash_l4t_t194_spi_emmc_p3668.xml
</partition>
<partition name="esp" type="data">
<size> 67108864 </size>
<filename> ESP_FILE </filename>
<partition_type_guid> C12A7328-F81F-11D2-BA4B-00A0C93EC93B </partition_type_guid>
<description> **Required.** EFI system partition with L4T Launcher. </description>
</partition>
</partition>
</partition>
</partition>
for OTA package, we modify relation file as Image_based_OTA_Examples.txt example 1.
To build the payload, show error as beneth
[ 1.2245 ] Concatenating BCT for chain B to bct_backup.img
[ 1.2245 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[ 1.2254 ] 2888+0 records in
[ 1.2292 ] 2888+0 records out
[ 1.2292 ] 2888 bytes (2.9 kB, 2.8 KiB) copied, 0.00347462 s, 831 kB/s
[ 1.2292 ]
[ 1.2292 ] Generating signatures
[ 1.2320 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key
[ 1.2323 ] Assuming zero filled SBK key
[ 1.3200 ] Warning: pub_key.key is not found
[ 1.3193 ] Parsing dev params for multi chains
[ 1.3193 ] Generating br-bct
[ 1.3215 ] Performing cfg overlay
[ 1.3215 ] ['/opt3_ssd_development/Nvidia_ORIN_AGX_NX_Project/OTA/NVIDIA_ORIN_AGX_NX_Linux.35.1_FlashEnv/deploy.evk/Linux_for_Tegra/bootloader/3195105/tmp537zc82n1.cfg']
[ 1.3215 ] Updating dev and MSS params in BR BCT
[ 1.3215 ] tegrabct_v2 --dev_param tegra194-br-bct-qspi-l4t.cfg --sdram /opt3_ssd_development/Nvidia_ORIN_AGX_NX_Project/OTA/NVIDIA_ORIN_AGX_NX_Linux.35.1_FlashEnv/deploy.evk/Linux_for_Tegra/bootloader/3195105/tmp537zc82n1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 1.3752 ] Updating bl info
[ 1.3777 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 1.3807 ] Updating smd info
[ 1.3828 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 --updatesmdinfo flash.xml.bin
[ 1.3843 ] Start sector for MSI_EMMC_START, expected >= 30274608, actual 30274560
Error: Return value 4
Command tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 --updatesmdinfo flash.xml.bin
signed_dir=/opt3_ssd_development/Nvidia_ORIN_AGX_NX_Project/OTA/NVIDIA_ORIN_AGX_NX_Linux.35.1_FlashEnv/deploy.evk/Linux_for_Tegra/R32x_R35-ToT_OTA/images-R35A-R35i/3668-100--
grep: /opt3_ssd_development/Nvidia_ORIN_AGX_NX_Project/OTA/NVIDIA_ORIN_AGX_NX_Linux.35.1_FlashEnv/deploy.evk/Linux_for_Tegra/bootloader/signed/flash.idx: No such file or directory
Warning: the file written to partition BCT is not found
Warning: the file written to partition MB1_BCT is not found
For error , we can not figure out what’s wrong.
would nvidia kindly show us how to modify ota package file for our customized partition layout??
