I followed the below steps to modify dtb file for my jetson nano board. But I only saw the modifications at the first time. It lost all my changes if reboot the board.
##on target:
root@yisp-desktop:~# cat /proc/device-tree/nvidia,dtsfilename
/dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a02.dts
##on host:
cd /home/jetson
#untar Jetson release package, ${L4T_RELEASE_PACKAGE}#
tar xpf /media/sf_F_DRIVE/temp_work/jetson/Tegra210_Linux_R32.3.1_aarch64.tbz2
#untar ‘L4T Sample Root File System’#
cd Linux_for_Tegra/rootfs/
tar xpf /media/sf_F_DRIVE/temp_work/jetson/Tegra_Linux_Sample-Root-Filesystem_R32.3.1_aarch64.tbz2
cd …
./apply_binaries.sh
#modify
cd /home/jetson
cp ./Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-a02.dtb old.dtb
dtc -I dtb -O dts -o old.dts old.dtb
vi old.dts
spi@7000d400 {
spi@0 {
compatible = “mcp251x”;
reg = <0x00>;
spi-max-frequency = <0x1f78a40>;
nvidia,enable-hw-based-cs;
nvidia,rx-clk-tap-delay = <0x07>;
spi@1 {
reg = <0x01>;
dtc -I dts -O dtb -o new.dtb old.dts
cp ./Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-a02.dtb tegra210-p3448-0000-p3449-0000-a02.dtb.origin
cp new.dtb ./Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-a02.dtb
##To generate an image to be flashed to an SD card
cd /home/jetson/Linux_for_Tegra
./tools/jetson-disk-image-creator.sh -o sd-blob.img -s 5G -b jetson-nano -r 200
200 for revision A02
cp sd-blob.img /media/sf_F_DRIVE/
##flash sd-blob.img to tf card on windows
then boot jetson nano board with tf card(new img). I see my modifications on board.
root@yisp-desktop:/home/yisp# cat /proc/device-tree/spi@7000d400/spi@0/compatible
mcp251x
root@yisp-desktop:/home/yisp# cat /proc/device-tree/spi@7000d400/spi@1/compatible
mcp251x
But If reboot jetson nano board, everything goes back.
root@yisp-desktop:/home/yisp# ls /proc/device-tree/spi@7000d400/
‘#address-cells’ dmas nvidia,clk-parents resets
clock-names interrupts phandle ‘#size-cells’
clocks iommus prod-settings spi@0
compatible linux,phandle reg status
dma-names name reset-names
spidev
