How to modify TX2 I2C6 pad drive strength
Hi everyone,
I use TX2,the bsp version is r32.3.1,I want to modify I2C6(DP-AUX-CH0) SCL and SDA pad drive strength, is any register to modify th DRVUP or DRVDN such as PADCTL_UART_CFG2TMC_GEN7_I2C_SCL_0? Thanks.
Have a check the PADCTL_UART_CFG2TMC_GEN7_I2C_SCL_0/PADCTL_UART_CFG2TMC_GEN7_I2C_SDA_0 in TRM.
You can try devmem2 to access these REG to try.
