Due to not spare GPIO on our current board. I try to multiplex a unused low-speed IO as GPIO. But i don’t konw how to do this, coud help to provide some guidance? For example, can UART0_TXD/RXD been multiplexed as SPI ready signal? Any reference for this? Thanks!
hello fh2077,
may I know what’s your actual use-case?
you may also refer to pinmux spreadsheets for pin configurations and also having customization.
for example,
you may modify the UART0_RXD signaling as GPIO pin, (i.e. GPIO3_PX.05)
thanks
hi Jerry,
My use-case is i need a gpio to indicate external SPI master(NX as slave) that SOC is ready to receive new data, to avoid external device sending too fast to overwrite/loss packet. And from SPI driver code, seems has limit to this GPIO, like can’t sleep. So i want to know where could I get those IO description. Also the mapping about the pin name UART0_RXD with DTS format like “nvidia,gpio-slave-ready = <&gpio TEGRA_GPIO(K, 4) 0>; /PK4/”. Thanks!
hello fh2077,
please check pinmux spreadsheets for the mappings of signal name and also ball name.
please refer to developer guide, Accessing GPIOs via “gpio” Device Labels,
thanks
According the spreadsheets, i still don’t fully understand the conversion rule. Could you shed more light? For example, is UART0_TXD equal to TEGRA_GPIO(X, 4)? And how do i know if it’s sleepable or not? Besides, seems the “gpio” Device Labels are written by software, if a GPIO didn’t label before(unused), how could i know it’s integer value? Thanks!
hello fh2077,
please check pinmux spreadsheets for the mappings of signal name and also ball name. you may check the board configuration files for confirmation,
i.e. $OUT/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-pinmux-p3668-a01.cfg
taking uart2_tx_px4 as an example,
it use signaling (DT property), UART2_TX; there’s a GPIO pin after ‘p’, so it’s TEGRA194_MAIN_GPIO(X, 4),
for example,
pinmux.0x0243d070 = 0x00000400; # uart2_tx_px4: uartb, tristate-disable, input-disable, io_high_voltage-disable, lpdr-disable
note,
Xavier and Xavier NX is based-on tegra194 series.
you may check the header files for reference,
i.e. $L4T_Sources/r32.5/Linux_for_Tegra/source/public/kernel/nvidia/include/dt-bindings/gpio/tegra194-gpio.h
OK, I see. Great appreciate your detail introduction!
