So I’ve been trying to setup opticalflow which is mentioned in the deepstream sample apps, but the issue is that when I proceed to run the sample it throws an error that,
Device does not support Optical flow functionality
Any idea how we could achieve the task of obtaining the direction vector which is supported on all machines?
I tried to run it on Jetson Nano and GTX device. Both the devices it threw the same error. I’m guessing it’s a feature only on RTX and Xavier device.
The ideal way of doing this would be to have a plugin? I’m not entirely sure but could you give a brief overview of the right way of doing it would be?
