I want to check if the preprocessed data meets expectations, so I want to obtain the image output in the extraInputProcess
of IInferCustomProcessor
. How can I get the frame’s image data here?
• DeepStream Version
• TensorRT Version
• The pipeline being used
Which sample do you use?
You can refer to the following code
/opt/nvidia/deepstream/deepstream/sources/libs/ds3d/datafilter/lidar_preprocess/lidar_preprocess_filter_impl.cpp
In fact, this problem is related to the configuration file you use, This is the key code
FrameGuard lidarFrame;
code = dataMap.getGuardData(key, lidarFrame);
if (!isGood(code)) {
LOG_ERROR("dataMap getGuardData %s kLidarFrame failed\n", key.c_str());
return code;
radars.emplace_back((float *)lidarFrame->base());
shape = lidarFrame->shape();
The above code can get the buffer pointer and shape of tensor
I apologize for not being clear. I am using nvinferserver element, and I want to obtain image data during the extraInputProcess. Below is the official demo:
#include <inttypes.h>
#include <unistd.h>
#include <cassert>
#include <unordered_map>
#include "infer_custom_process.h"
#include "nvbufsurface.h"
#include "nvdsmeta.h"
typedef struct _GstBuffer GstBuffer;
using namespace nvdsinferserver;
#defin INFER_ASSERT assert
class NvInferServerCustomProcess : public IInferCustomProcessor {
// memtype for ``extraInputs``, set ``kGpuCuda`` for performance
void supportInputMemType(InferMemType& type) override { type = InferMemType::kGpuCuda; }
// for LSTM loop. return false if not required.
bool requireInferLoop() const override { return false; }
// skip extraInputProcess if there is no extra input tensors
NvDsInferStatus extraInputProcess(const std::vector<IBatchBuffer*>& primaryInputs, std::vector<IBatchBuffer*>& extraInputs, const IOptions* options) override {
return NVDSINFER_SUCCESS;
// output tensor postprocessing function.
NvDsInferStatus inferenceDone(const IBatchArray* outputs, const IOptions* inOptions) override
GstBuffer* gstBuf = nullptr;
std::vector<uint64_t> streamIds;
NvDsBatchMeta* batchMeta = nullptr;
std::vector<NvDsFrameMeta*> frameMetaList;
NvBufSurface* bufSurf = nullptr;
std::vector<NvBufSurfaceParams*> surfParamsList;
int64_t unique_id = 0;
INFER_ASSERT (inOptions->getValueArray(OPTION_NVDS_SREAM_IDS, streamIds) == NVDSINFER_SUCCESS);
INFER_ASSERT(inOptions->getObj(OPTION_NVDS_BUF_SURFACE, bufSurf) == NVDSINFER_SUCCESS);
INFER_ASSERT(inOptions->getObj(OPTION_NVDS_BATCH_META, batchMeta) == NVDSINFER_SUCCESS);
INFER_ASSERT(inOptions->getInt(OPTION_NVDS_UNIQUE_ID, unique_id) == NVDSINFER_SUCCESS);
INFER_ASSERT(inOptions->getValueArray(OPTION_NVDS_BUF_SURFACE_PARAMS_LIST, surfParamsList) == NVDSINFER_SUCCESS);
INFER_ASSERT(inOptions->getValueArray(OPTION_NVDS_FRAME_META_LIST, frameMetaList) == NVDSINFER_SUCCESS);
uint64_t nsTimestamp = UINT64_MAX; // nano-seconds
if (inOptions->hasValue(OPTION_TIMESTAMP)) {
INFER_ASSERT(inOptions->getUInt(OPTION_TIMESTAMP, nsTimestamp) == NVDSINFER_SUCCESS);
std::unordered_map<std::string, SharedIBatchBuffer> tensors;
for (uint32_t i = 0; i < outputs->getSize(); ++i) {
SharedIBatchBuffer outTensor = outputs->getSafeBuf(i);
INFER_ASSERT(outTensor);
auto desc = outTensor->getBufDesc();
tensors.emplace(desc.name, outTensor);
// parsing output tensors
float* boxesPtr = (float*)tensors["output_bbox"]->getBufPtr(0);
auto& bboxDesc = tensors["output_bbox"]->getBufDesc();
float* scoresPtr = (float*)tensors["output_score"]->getBufPtr(0);
float* numPtr = (float*)tensors["output_bbox_num"]->getBufPtr(0);
int32_t batchSize = bboxDesc.dims.d[0]; // e.g. tensor shape [Batch, num, 4]
std::vector<std::vector<NvDsInferObjectDetectionInfo>> batchedObjs(batchSize);
// parsing data into batchedObjs
// attach to NvDsBatchMeta
for (int iB = 0; iB < batchSize; ++iB) {
const auto& objs = batchedObjs[iB];
for (const auto& obj : objs) {
NvDsObjectMeta* objMeta = nvds_acquire_obj_meta_from_pool(batchMeta);
objMeta->unique_component_id = unique_id;
objMeta->confidence = obj.detectionConfidence;
objMeta->class_id = obj.classId;
objMeta->rect_params.left = obj.left;
objMeta->rect_params.top = obj.top;
objMeta->rect_params.width = obj.width;
objMeta->rect_params.height = obj.height;
// other settings
// add NvDsObjectMeta obj into NvDsFrameMeta frame.
nvds_add_obj_meta_to_frame(frameMetaList[iB], objMeta, NULL);
extern "C" {
IInferCustomProcessor* CreateInferServerCustomProcess(const char* config, uint32_t configLen)
return new NvInferServerCustomProcess();
I want to obtain image data in GPU CUDA memory type here.
Due to differences between different devices and versions, please provide complete information as applicable to your setup.
I don’t understand your purpose
Do you want the original image or the normalized image?
You can get the original image from nvbufsurface
extraInputProcess
is used for user-defined normalization implementation. Cannot be used to dump the default normalized tensor.
You can refer to NvDsInferStatus NetworkPreprocessor::transformImpl
in /opt/nvidia/deepstream/deepstream/sources/libs/nvdsinferserver/infer_preprocess.cpp
This function can get the normalized tensor.
