Hi, this time I’ve successfully open my e-con camera using gstreamer pipeline on terminal using this command :
gst-launch-1.0 v4l2src device="/dev/video1" ! "video/x-raw,width=1920,height=1080,format=UYVY" ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12' ! nvoverlaysink
Now I want to open my camera using C++ code with OpenCV but I keep failing to do it, here’s my code:
#include "opencv2/opencv.hpp"
#include <opencv2/highgui.hpp>
#include <iostream>
using namespace std;
using namespace cv;
int main(){
// Create a VideoCapture object and open the input file
// If the input is the web camera, pass 0 instead of the video file name
const char* gst = "v4l2src device='/dev/video1' ! 'video/x-raw,width=1920,height=1080,format=UYVY' ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12' ! appsink";
VideoCapture cap(gst);
// Check if camera opened successfully
if(!cap.isOpened()){
cout << "Error opening video stream or file" << endl;
return -1;
while(1){
Mat frame;
// Capture frame-by-frame
cap >> frame;
// If the frame is empty, break immediately
if (frame.empty())
break;
// Display the resulting frame
imshow( "Frame", frame );
// Press ESC on keyboard to exit
char c=(char)waitKey(25);
if(c==27)
break;
// When everything done, release the video capture object
cap.release();
// Closes all the frames
destroyAllWindows();
return 0;
I compile with
g++ camtest.cpp -o output `pkg-config --cflags --libs opencv`
and produces this error
VIDEOIO ERROR: V4L: device v4l2src device='/dev/video1' ! 'video/x-raw,width=1920,height=1080,format=UYVY' ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12' ! appsink: Unable to query number of channels
(output:13844): GStreamer-CRITICAL **: 11:22:32.713: gst_element_make_from_uri: assertion 'gst_uri_is_valid (uri)' failed
(output:13844): GStreamer-CRITICAL **: 11:22:32.761: gst_element_make_from_uri: assertion 'gst_uri_is_valid (uri)' failed
(output:13844): GLib-GObject-WARNING **: 11:22:32.762: invalid cast from 'GstAppSink' to 'GstBin'
(output:13844): GStreamer-CRITICAL **: 11:22:32.763: gst_bin_iterate_elements: assertion 'GST_IS_BIN (bin)' failed
(output:13844): GStreamer-CRITICAL **: 11:22:32.763: gst_iterator_next: assertion 'it != NULL' failed
(output:13844): GStreamer-CRITICAL **: 11:22:32.763: gst_iterator_free: assertion 'it != NULL' failed
OpenCV Error: Unspecified error (GStreamer: cannot find appsink in manual pipeline
) in cvCaptureFromCAM_GStreamer, file /home/nvidia/src/opencv-3.4.0/modules/videoio/src/cap_gstreamer.cpp, line 805
VIDEOIO(cvCreateCapture_GStreamer (CV_CAP_GSTREAMER_FILE, filename)): raised OpenCV exception:
/home/nvidia/src/opencv-3.4.0/modules/videoio/src/cap_gstreamer.cpp:805: error: (-2) GStreamer: cannot find appsink in manual pipeline
in function cvCaptureFromCAM_GStreamer
Any help will be appreciated thanks
