How to package to compile and burn successfully Image.
Let others burn and test in the future …
use “./flash.sh jetson-xavier mmcblk0p1”
Will copy Linux_for_Tegra/bootloader, Linux_for_Tegra/rootfs
Files related to Linux_for_Tegra/images
These related files are too complicated flash_image.log (1.5 MB)
Directly packaging the entire BSP will be too large and there will be compiled *.o files…
Also, during production, it should be directly packaged as an Image file and burned directly…
you could create a Massflash blob, (mfi_*.tbz2) which is portable, and encrypted.
as you can see, there’re tools for image flashing, so the script file has included; regarding to the *.cfg, and *.xml files, they’re used for board configuration.
here’s see-also topic Topic 186001, it shows the roughly steps to create a mass flashing tarball.
thanks
This tool is part of the Linux BSP package and is available in the Linux_for_Tegra folder. Instructions for using the tool are included in README_Massflash.txt, located in the same folder.
