Hi!
Is it possible to speed up IIR filter with CUDA? As IIR filter is defined recursively it’s quite challenging.
https://docs.scipy.org/doc/scipy/reference/generated/scipy.signal.lfilter.html#scipy.signal.lfilter
Hi!
This is outside my area of expertise. Have you performed a literature search? A simple search of the literature appears to indicate that parallelized GPU implementations of IIR filters are possible, for certain specific use cases and/or subject to specific constraints.
I used the following search terms with Google Scholar: GPU IIR filter
maybe our old paper could help you:
