How to pass a device allocated array into a function properly in Fortran?
Hi I am new to Cuda but I am trying to allocate an array in my main program, and pass it to another function that
combines a few related Cuda/fft calls but it seems like the device array is being read as not associated when passed into the function, I understand the function itself is on the host but I am unsure how else to do this here is an example of what I am talking about:
subroutine foo(example_device_array)
    real,Dimension(:,:,:),intent(inout),device::example_device_array
    !! Error happens in here upon trying to read in variable
    !! Happens with or withour allocatable keyword inside here
end subroutine foo
program main
    use example_kernels
    implicit none
    integer, parameter:: nx =20 , ny = 20, nz = 20
    real, Dimension(:,:,:), allocatable, device :: example_device_array
    allocate(example_device_array(64,64,64))
    call fill_out_device_array<<<256,256>>>(example_device_array)
    call cudaDeviceSynchronize()
    call foo(example_device_array)
end program main
I hope i havent oversimplified, I realize theres a chance it gets messed up in the previous kernel call but its fairly complex so I first wanted to check whether it was an issue with how im passing the variable.
Really appreciate any insights.
Hi novus and welcome!
CUDA Fortran requires F90 interfaces in order to pass device arrays. Does it work if you put “foo” in a module so an implicit interface is created?
-Mat
Hi Matt!
Sorry it took me a while to get to it, that worked! Thanks for the advice.
