**• Hardware Platform (Jetson / GPU)**GPU
• DeepStream Version 5.0
• TensorRT Version 7.0.0
• NVIDIA GPU Driver Version (valid for GPU only) GeForce Rtx 2080ti
• Issue Type( questions, new requirements, bugs) questions
Hi Team,
My case is to create dummy vehicle objects and pass them to nvDCF tracker for tracking. My pipeline is like deepstream-app but without primary gie, and I will use dummy objects as detected objects.
I implemented this by adding a probe at the sink pad of tracker plugin, and use nvds_acquire_obj_meta_from_pool() and nvds_add_obj_meta_to_frame() api to create and add 2 dummy moving objects to batched metadata. I can successfully access the metadata of the 2 dummy objects after tracker, as well as draw the bounding boxes of the 2 dummy objects in OSD during the whole video. However, the object id of the 2 dummy objects will always be the same as “0”, and bounding box location and confidence dumped in kitti files are always 0 too.
motorbike-dummy 0 0.0 0 0.0 0.000000 0.000000 0.000000 0.000000 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.000000
motorbike-dummy 2 0.0 0 0.0 0.000000 0.000000 0.000000 0.000000 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.000000
I am not sure whether this means the dummy objects have not been passed to tracker or not been tracked at all? Or maybe where and how can I verify the results? Any api for me to check if those dummy objects have been set as detected objects in the track list for the tracker?
Partial code:
NvDsObjectMeta *obj_meta = NULL;
obj_meta = nvds_acquire_obj_meta_from_pool (batch_meta);
NvDsObjectMeta *parent_obj_meta = NULL;
obj_meta->unique_component_id = DUMMY_UNIQUE_ID;
obj_meta->confidence = 0.9;
obj_meta->class_id = 3; //motorbike
sprintf(obj_meta->obj_label, “%s”, “motorbike-dummy”);
NvOSD_RectParams & rect_params = obj_meta->rect_params;
NvOSD_TextParams & text_params = obj_meta->text_params;
rect_params.left = 100 + frame_meta->frame_num * 3;
gint increment_y = frame_meta->frame_num * 3;
if (increment_y > frame_meta->source_frame_height - 100) {
increment_y = frame_meta->frame_num * 1;
rect_params.top = 100 + increment_y;
rect_params.width = 100;
rect_params.height = 150;
text_params.x_offset = rect_params.left;
text_params.y_offset = rect_params.top - 10;
text_params.set_bg_clr = 1;
text_params.text_bg_clr = (NvOSD_ColorParams) {
0, 0, 0, 1};
text_params.font_params.font_size = 11;
text_params.font_params.font_color = (NvOSD_ColorParams) {
1, 1, 1, 1};
nvds_add_obj_meta_to_frame (frame_meta, obj_meta, parent_obj_meta);
Any help will be very appreciated!
