How to pass RTP stream from one terminal to other terminal
Software Version
[✓] DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[✓] Linux
QNX
other
Hardware Platform
[✓] other
SDK Manager Version
1.9.3.10904
other
Host Machine Version
[✓] native Ubuntu Linux 20.04 Host installed with DRIVE OS Docker Containers
other
Hello Team,
I am trying to transfer RTP stream inside GStreamer docker from one terminal to other but I am getting blank window.
To transmit an RTP stream inside a GStreamer Docker container from one terminal to another, using following command:
gst-launch-1.0 videotestsrc pattern=snow ! ‘video/x-raw,width=640,height=480,framerate=30/1’ ! videoconvert ! x264enc ! rtph264pay ! udpsink host=224.0.0.251 port=5
353
To receive the RTP stream in another terminal, using the following command:
gst-launch-1.0 udpsrc port=5353 caps=“application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264” ! rtph264depay ! avdec_h264 ! video
convert ! autovideosink
For more information, I have attached a screenshot.
Thanks,
Kajal
Dear @kajal.dhavale1,
May I know if you are using P3710(DRIVE AGX Orin Devkit?
Dear @SivaRamaKrishnaNV ,
No actually, I am trying it on local native Linux machine which is work for x86 architechture.
Also I need to try it on NVIDIA Orin later as I am facing open network issue for Orin.
It appears that the issue you’re experiencing with transferring the RTP stream using GStreamer Docker is not directly related to our platform. We recommend seeking assistance elsewhere for this specific problem.
