I am trying to use texture reference API by using tex3d. But I am unable to get its value after all calculations. Last, of the program, I am printing all values, but there no values are printing. Can you help me to get all values after kernel calculations?
#include<stdio.h>
#include<cuda.h>
texture<float,cudaTextureType3D,cudaReadModeElementType> texreference;
__global__ void kernel(float* dmatrix, int size)
int loop;
int xindex;
int yindex;
int zindex;
// calculate each thread global index
xindex=blockIdx.x*blockDim.x+threadIdx.x;
yindex=blockIdx.y*blockDim.y+threadIdx.y;
for (loop=0;loop<size;loop++)
zindex=loop;
// fetch cuda array through texture reference
dmatrix[zindex*size*size + yindex*size+xindex]=
tex3D(texreference,xindex,yindex,zindex);
printf("output = %f\n",dmatrix[zindex*size*size + yindex*size+xindex]);
return;
int main(int argc, char** argv)
int size=8;
dim3 blocknum;
dim3 blocksize;
float* hmatrix;
float* dmatrix;
cudaArray* cudaarray;
cudaExtent volumesize;
cudaChannelFormatDesc channel;
cudaMemcpy3DParms copyparms={0};
// allocate host and device memory
hmatrix=(float*)malloc(sizeof(float)*size*size*size);
cudaMalloc((void**)&dmatrix,sizeof(float)*size*size*size);
// initialize host array before usage
for(int loop=0; loop<size*size*size;loop++)
hmatrix[loop]= loop ;
printf("%f\n", hmatrix[loop] );
// set cuda array volume size
volumesize=make_cudaExtent(size,size,size);
// create channel to describe data type
channel=cudaCreateChannelDesc<float>();
// allocate device memory for cuda array
cudaMalloc3DArray(&cudaarray,&channel,volumesize);
// set cuda array copy parameters
copyparms.extent=volumesize;
copyparms.dstArray=cudaarray;
copyparms.kind=cudaMemcpyHostToDevice;
copyparms.srcPtr= make_cudaPitchedPtr((void*)hmatrix,sizeof(float)*size,size,size);
cudaMemcpy3D(©parms);
// set texture filter mode property
// use cudaFilterModePoint or cudaFilterModeLinear
texreference.filterMode=cudaFilterModePoint;
// set texture address mode property
// use cudaAddressModeClamp or cudaAddressModeWrap
texreference.addressMode[0]=cudaAddressModeWrap;
texreference.addressMode[1]=cudaAddressModeWrap;
texreference.addressMode[2]=cudaAddressModeClamp;
// bind texture reference with cuda array
cudaBindTextureToArray(texreference,cudaarray,channel);
blocksize.x=8;
blocksize.y=8;
blocksize.z=8;
blocknum.x=(int)ceil((float)size/8);
blocknum.y=(int)ceil((float)size/8);
blocknum.z=(int)ceil((float)size/8);
// execute device kernel
kernel<<<blocknum,blocksize>>>(dmatrix,size);
// unbind texture reference to free resource
cudaUnbindTexture(texreference);
// copy result array from device to host memory
const int bytes = sizeof(float)*size*size*size;
cudaMemcpy(hmatrix,dmatrix,bytes,cudaMemcpyDeviceToHost);
// free host and device memory
cudaFree(dmatrix);
cudaFreeArray(cudaarray);
free(hmatrix);
return 0;
This is my code which I am using.
I am printing values from code line numbers 113. this all is same as previous as input.
