I want to know the principle.
Can you explain how to pass the decoded image to the EGL renderer (principle) without additional memory copy?
Thank you.
The implementation of redering is
/usr/src/jetson_multimedia_api/samples/common/classes/NvEglRenderer.cpp
The function is
* Renders a buffer.
* This method waits until the rendering time of the next buffer,
* caluclated from the rendering time of the last buffer and the
* render rate in frames per second (fps). This is a blocking
* call.
* @param[in] fd Specifies the file descriptor (FD) of the exported buffer
* to render.
* @return 0 for success, -1 otherwise.
int render(int fd);
