We have been able to encrypt the ‘/home’ partition. is it posible to encrypt the whole root partition ‘/’? Do you have any documentation on how to achieve this?
thanks
thanks
Your topic will be best served in the Jetson category.
I will move this post over for visibility.
Cheers,
Tom
Hi chen.zhe8,
Are you using the devkit or custom board for Orin NX?
Yes. We support disk-encryption for Orin NX.
Please help to answer the above questions from me and I’ll share the correct document link with you.
Hi kevin
I am currently using the devkit board for Orin NX and NVIDIA DRIVE OS 6.0.10
thanks
The Jetson Orin NX is not able to work with DRIVE OS. Could you confirm with devkit you’re using?
Besides, for DRIVE OS issue, you should open topic at Latest DRIVE AGX Orin/DRIVE AGX Orin General topics - NVIDIA Developer Forums.
But you’re using DRIVE OS 6.0.10 which should be supported via NVOnline, please discuss with your internal team to know where is the right place to get the support.
HI kay
sorry, I confused the concept of jetson orin board. I am currently using the custom board and NVIDIA DRIVE OS 6.0.8. The project may ultimately need to be used on NVIDIA DRIVE OS 6.0.10, so I was wondering if it is possible to directly obtain the information for NVIDIA DRIVE OS 6.0.10. I think this question belongs to security module.
thanks
I will suggest you to discuss with your internal tema to know how to get the support via NVOnline.
The forum is not the right place for your case.
HI kay
I want to know which types of issues should be supported here, and which types require support on nvonline? Can you give me a definition about this?
thanks
Both of our company have sign the agreement, so you should get the support via NVOnline, not via forum.
If issue is specific with Jeton devkit/platform, then can get support via Jetson forum.
HI kay
Thank you for your answer. I thought this was a general question.
Even that’s a general question, but depends on your project scope and the planed DRIVE OS 6.0.10, that will be better to get answer/support via the NVOnline support team with your company.
