Hi. I’m using Orin NX.
I found when I connect it to PC, it would generate two usb connections: usb0 and rndis0.
Is it possible to remove one of these permanently?
Thanks in advance.
Thanks in advance.
You could disable /opt/nvidia/l4t-usb-device-mode/nv-l4t-usb-device-mode.service.
Along that line for what @WayneWWW mentions:
# Temporary stop:
sudo systemctl stop nv-l4t-usb-device-mode.service
# disable:
sudo systemctl disable nv-l4t-usb-device-mode.service
# enable:
sudo systemctl enable nv-l4t-usb-device-mode.service
# query status:
sudo systemctl status nv-l4t-usb-device-mode.service
@WayneWWW @linuxdev Thanks for your replies.
I found that maybe it’s more straightforward to do this:
open
/opt/nvidia/l4t-usb-device-mode/nv-l4t-usb-device-mode-config.sh
set
enable-rndis=0
to disablerndis0
, or setenable-ecm=0
to disableusb0
Then, run systemctl restart nv-l4t-usb-device-mode.service
to take effect.
