How to port OAK8x module to Jetson Nano
Hi Will,
I am not sure why you are seeing this problem. I did not see it at my end. I think this can be checked separately. But are you able to proceed now with what you originally wanted to do?
Thanks,
Sameer.
Hi Sameer,
I want to transfer 1 byte data (0x55) using devmem2 tools as the following command, but I only see 1 clock, not 8 clocks.
echo on > /sys/devices/7000d400.spi/power/control
devmem2 0x7000d58c h
devmem2 0x7000d58c h 0x0000
devmem2 0x7000d58c b 0x00
devmem2 0x7000d400 w 0x73d08000
devmem2 0x7000d414 h
devmem2 0x7000d416 b
devmem2 0x7000d410 w
devmem2 0x7000d410 w 0xff0000
devmem2 0x7000d400 w 0x73e01807
devmem2 0x7000d508 b 0x55
devmem2 0x7000d424 h 0x0000
devmem2 0x7000d400 w 0xf3e01807
devmem2 0x7000d410 w 0x40ff0001
devmem2 0x7000d588 w
root@pesi-desktop:/home/pesi# cat /sys/kernel/debug/clk/clk_summary | grep sbc1*
          sbc4                                              1            1    12000000    12000000          0 0
                            sbc4.sclk                       0            0    51000000   102000000          0 0
                            sbc3.sclk                       0            0    51000000   102000000          0 0
                            sbc2.sclk                       0            0    51000000   102000000          0 0
                            sbc1.sclk                       0            0    51000000   102000000          0 0
       sbc1                                                 1            1      984616     1000000          0 0
       sbc3                                                 0            0    19200000    19200000          0 0
       sbc2                                                 0            0    19200000    19200000          0 0
Thanks,
Will
Hi Will,
I don’t think you would need all the clocks. Are you able to write and readback the expected values? If yes, then you are good to proceed with your experiment.
However I have requested internally to provide you expert advice on SPI usage.
Thanks,
Sameer.
Hi Sameer,
Yes, I can write/read the register, but how do I send 1 byte (8 clocks) with devmem2 tool?
Thanks,
Will
Could you try the REG access from the driver to confirm it.
