How to porting HDMI2MIPI IC lt6911uxc
In hardware/nvidia/platform/t23x/mandalore/kernel-dts/cvb/tegra234-camera-p3715.dtsi
can see
Is this a verified program??
How to verify lt6911 on ORIN EVB???
hello channinglan,
it’s tested on other Orin based platforms instead of AGX Orin developer kit.
I want to port to ORIN EVK, how should I modify it? ?
Is it possible to refer to this part for transplantation?
hello channinglan,
you may port the device tree for AGX Orin.
as you can see… it’s dtsi files from mandalore, whereas AGX Orin uses concord.
