I want to profile the Nvidia Bluefield-2 SmartNIC. I want to record :
events, throughput, latency, accelerator use (like RegEx module, Sha-2 module) of an application running on
Bluefield;
packets I/O, PCIe throughput, DRAM activity, hardware unit (like core) utilization;
tracing the DOCA libraries that an application on Bluefield use.
I am not sure how to start and if there is any API to access these data. Any pointers are welcome.
Hi kmbappe,
Welcome to the NVIDIA Developer Forums!
DOCA has a Telemetry service which tracks many of these attributes - deployment guide and tracked metrics are available in the DOCA documentation:
https://docs.nvidia.com/doca/sdk/nvidia+doca+telemetry+service+guide/index.html
DOCA driver and library APIs are also documented here:
https://docs.nvidia.com/doca/sdk/api+references/index.html
If the above does not cover your use case, and you have active NVIDIA Support entitlement, we highly recommend opening a support ticket with NVIDIA Enterprise Experience: https://enterprise-support.nvidia.com/s/create-case
Best regards,
system
Closed
June 17, 2024, 3:19pm
3
