How to programmatically modify attibutes(especially for the datatype of token) of an OGN?
I created an extension to programmatically connect some customized OGNs inside of a SDG Pipeline once an animation is triggered.
Nevertheless, I also want to modify certain attribute, e.g., inputs:renderVar of this OGN called SD Render Var To Raw Array. Because for my project I need rendering output of HDRColor instead of the default LDRColor.
However, the datatype of this input attribute is predefined as “token”, which means I can’t simply assign a string “HdrColor” to this input since the datatype doesn’t match to each other.
Therefore, my question would be is it possible to programmatically modify/assign input variables with datatype defined as token?
Thanks in advance for considering my request!
Best regards,
Y.W.
Hi there,
can you provide details on how the SDG pipeline is created? Does the pipeline work is you use LdrColor or LdrColorSD instead of HdrColor?
Best,
Andrei
