@Andrey and linuxdev, thanks for the tips.
The SD card is in ext4 format. I have a host PC pretty much doing nothing but to flash the DTB for TX2. It doesn’t come with SD reader, so I plug the SD into a USB3 card reader.
Here are the output for some commands on the host PC.
‘sudo lsblk -l’
sdb 8:16 1 29.5G 0 disk
sdb1 8:17 1 29.5G 0 part
sr0 11:0 1 1024M 0 rom
sda 8:0 0 232.9G 0 disk
sda2 8:2 0 1K 0 part
sda5 8:5 0 7.9G 0 part [SWAP]
sda1 8:1 0 225G 0 part /
‘sudo e2fsck /dev/sdb1’ (took a few minutes to respond)
e2fsck 1.42.13 (17-May-2015)
/dev/sdb1: recovering journal
Superblock needs_recovery flag is clear, but journal has data.
Run journal anyway<y>? yes
e2fsck: unable to set superblock flags on /dev/sdb1
/dev/sdb1: ********** WARNING: Filesystem still has errors **********
‘sudo fsck.ext4 /dev/sdb1’ (similar result as to ‘e2fsck’)
fsck.ext4: unable to set superblock flags on /dev/sdb1
The ‘gdisk’ command, however gives some interesting report. I don’t know how to decipher it though.
‘sudo gdisk -l /dev/sdb’
GPT fdisk (gdisk) version 1.0.1
Partition table scan:
MBR: MBR only
BSD: not present
APM: not present
GPT: not present
Found invalid GPT and valid MBR; converting MBR to GPT format
in memory.
Warning! Secondary partition table overlaps the last partition by
33 blocks!
You will need to delete this partition or resize it in another utility.
Disk /dev/sdb: 61896704 sectors, 29.5 GiB
Logical sector size: 512 bytes
Disk identifier (GUID): C9E1BD58-1391-4ED3-AFC6-787226044014
Partition table holds up to 128 entries
First usable sector is 34, last usable sector is 61896670
Partitions will be aligned on 2048-sector boundaries
Total free space is 8158 sectors (4.0 MiB)
Number Start (sector) End (sector) Size Code Name
1 8192 61896703 29.5 GiB 0700 Microsoft basic data
Looks like I have to give up, doesn’t it?
P.S.
Here are the ‘dmesg --follow’ output (pretty much repeating the same message)
[ 1495.382862] sd 6:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_SENSE
[ 1495.382866] sd 6:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 1495.382868] sd 6:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 1495.382871] sd 6:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 01 c4 20 00 00 00 08 00
[ 1495.382873] blk_update_request: I/O error, dev sdb, sector 29630464
[ 1495.382879] Buffer I/O error on dev sdb1, logical block 3702784, lost async page write
[ 1495.424934] VFS: Dirty inode writeback failed for block device sdb1 (err=-5).
[ 1546.822406] sdb: sdb1
