First, I try this:
gst-launch-1.0 -v videotestsrc ! avenc_flv ! flvmux ! rtmpsink location=‘rtmp://192.168.1.108/live/livestream live=1’
and it can work successfully.
However, when I try to publish x264 encode data, it failed:
gst-launch-1.0 videotestsrc ! ‘video/x-raw, format=(string)I420, width=(int)640, height=(int)480’ ! omxh264enc ! ‘video/x-h264, stream-format=(string)byte-stream’ ! h264parse ! qtmux ! rtmpsink location=‘rtmp://192.168.1.108/live/livestream live=1’
the error is that:
could not link qtmux0 to rtmpsink0.
gst-launch-1.0 -v videotestsrc ! omxh265enc ! ‘video/x-h265,stream-format=(string)byte-stream’ ! rtmpsink location=‘rtmp://192.168.1.108/live/livestream live=1’
This is also a wrong code, the error is that:
could not link omxh265enc-moxh265enc0 to rtmpsink0.
If you look at rtmpsink capabilities, you’ll see that it accepts video/x-flv as input:
gst-inspect-1.0 rtmpsink
Factory Details:
Rank primary (256)
Long-name RTMP output sink
Klass Sink/Network
Description Sends FLV content to a server via RTMP
Author Jan Schmidt <thaytan@noraisin.net>
Pad Templates:
[b] SINK template: 'sink'
Availability: Always
Capabilities:
video/x-flv[/b]
You can use flvmux in order to provide this to rtmpsink. If you look at flvmux sink (input) capabilities:
gst-inspect-1.0 flvmux
Factory Details:
Rank primary (256)
Long-name FLV muxer
Klass Codec/Muxer
Description Muxes video/audio streams into a FLV stream
Author Sebastian Dröge <sebastian.droege@collabora.co.uk>
Pad Templates:
SINK template: 'video'
Availability: On request
Has request_new_pad() function: gst_flv_mux_request_new_pad
Capabilities:
video/x-flash-video
video/x-flash-screen
video/x-vp6-flash
video/x-vp6-alpha
[b] video/x-h264
stream-format: avc[/b]
you’ll see it expects a h264 stream in avc format.
So you may just try something like:
gst-launch-1.0 -v videotestsrc ! omxh264enc ! 'video/x-h264,stream-format=(string)avc' ! flvmux ! rtmpsink location='rtmp://192.168.1.108/live/livestream live=1'
Thanks for Honey_Patouceul’s reply!
I also want to know how to publish x265 encode data. It seems that flvmux doesn’t support x-h265 as its Capabilities.
Following on flvmux with h265 as well - did you find out anything about getting rtmp working with h265 ? cheers
