When I ran OpenGl applications in full screen mode, I could hit ESC or “Q” or “q” to quit.
I could not figure out how to quit “nvgstcapture” in full screen mode.
I tried to hit “q” everywhere on screen but could not quit “nvgstcapture”.
Does anyone know how to quit “nvgstcapture” in full screen mode?
Thanks in advance.
hi yahoo2016,
may i know which BSP version you were testing?
please also share full input commands you were used.
thanks
I’m using the latest Jetpack 2.3, i.e., L4T R24.2.1.
I tried both Nvidia and Leopard CSI-2 cameras, using:
gst-launch-1.0 nvcamerasrc fpsRange=“30.0 30.0” ! ‘video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)I420, framerate=(fraction)30/1’ ! nvtee ! nvvidconv flip-method=2 ! ‘video/x-raw(memory:NVMM), format=(string)I420’ ! nvoverlaysink -e
from this post:
https://devtalk.nvidia.com/default/topic/966704/jetson-tx1/jetson-tx1-onboard-camera-does-it-really-work-/post/4979676/#4979676
hi yahoo2016,
for the gst-launch-1.0. you should use ctrl^c to shutdown the pipeline, it will send EOS signal since you had set “-e” option.
BTW, nvgstcapture-1.0 is support ‘q’ command to shutdown/terminate the streaming.
thanks
I believe I tried ctl-c, ctl-x and ctl-z for “gst-lauch”, I’ll try them again.
When I used “nvgtscapture-1.0” for Leopart IMX274 camera, I got only 640x480 display which is not full screen on 4K monitor.
“nvgtscapture-1.0 --help” showed 9 different resolutions, but when I tried “nvgtscapture-1.0 --video-res=x” (x=6,7,8, or 9), display stayed at 640x480 resolution.
I could not figure out how to change resolution and verify full screen mode using “nvgtscapture-1.0”. Leopart support suggested using “nvgtscapture-1.0 m 1 -video-res=x”, but it did not change video res.
I figured out I should use “nvgtscapture-1.0 --prev-res=x” to set live display resolution.
“q” did work for “nvgtscapture-1.0”
