Did you boost CPU/GPU/EMC to max clock?
sudo nvpmodel -m 0
sudo jetson_clocks
Did you turn off osd and tiler?
about tracker setting, did you follow part: Use the max_perf setting for tracker
The numbers are obtained with sample_1080p_h265.mp4.
This performance is expected due to a heavier model. We will keep updating to newer models from time to time and adding performance for older ones may be dropped.
