dgarba
February 16, 2021, 3:53am
1
Software Version
DRIVE OS Linux 5.2.0
[*] NVIDIA DRIVE™ Software 10.0 (Linux)
other DRIVE OS version
other
Target Operating System
[*] Linux
QNX
other
Hardware Platform
[*] NVIDIA DRIVE™ AGX Xavier DevKit (E3550)
other
SDK Manager Version
[*] 1.4.0.7363
other
Host Machine Version
[*] native Ubuntu 18.04
other
Does NvMedia Framework offer a way to read the camera sensor temperature? I am using IMX390 sensors and I want to read the camera sensor temperature register.
Thanks in advance for any help.
Best regards,
-Daniel
Dear @dgarba ,
We will check internally and update you. May I know why you are looking for this? Any use case?
dgarba
February 16, 2021, 10:51pm
3
Thanks @SivaRamaKrishnaNV .
The use case is to assess how fogging on the lens is related to the camera temperature.
Best regards,
-Daniel
Dear @dgarba ,
May I know if you want to know about the sensor temperature or separate temperature HW which is out of the sensor?
dgarba
February 17, 2021, 6:09pm
6
Dear @SivaRamaKrishnaNV ,
I want to read the internal camera temperature sensor, not an external temperature sensor HW.
Dear @dgarba ,
we do not have any APIs in Nvmedia to achieve this. Could you check with vendor too?
dgarba
March 3, 2021, 12:52am
8
Hi @SivaRamaKrishnaNV ,
Can the NvMediaISCTemperature Struct be used to read camera sensor temperature? If not what is it intended for?
https://docs.nvidia.com/drive/drive-os-5.2.0.0L/drive-os/DRIVE_OS_Linux_SDK_Development_Guide/baggage/structNvMediaISCTemperature.html
float_t NvMediaISCTemperature::sensorTempCelsius[NVMEDIA_ISC_MAX_NUM_TEMPERATURES]
→ Holds the values of active sensor temperatures in degrees Celsius.
Best regards,
-Daniel
Dear @dgarba ,
My apologies for the delay.
SIPL provides the method to deliver the sensor temperature (https://docs.nvidia.com/drive/drive-os-5.2.0.0L/drive-os/DRIVE_OS_Linux_SDK_Development_Guide/baggage/structnvsipl_1_1INvSIPLClient_1_1ImageMetaData.html#aa8237ea1bb2c21b73964996276d71658 ) if the image sensor(e.g. AR0820) driver implements a logic to parse the temperature from the embedded data. Please see if it helpful?
