How to read .engine model's mask segmentation output from `tao mask_rcnn inference` command?
I’ve successfully trained and exported my custom mask-rcnn model using the TAO Toolkit.
Using the tao mask_rcnn inference command on the .engine file I can output the prediction information to json files. All of the json fields are readable except for the segmentation mask which is encoded. How do I converted the encoded segmentation data back to numerical values?
Example Json entry:
{‘area’: 19812,
‘bbox’: [278, 1002, 254, 78],
‘category_id’: 1,
‘id’: 0,
‘image_id’: ‘frame_003740.PNG’,
‘is_crowd’: 0,
‘score’: 0.83984375,
‘segmentation’: {‘counts’: ‘fWV97aQ12M2O001N101O001O001O1N101O0O010O100O1O01000O10000000000O1000000O2O00000O1000000DWOhoNj0XP1VOhoNj0WP1WOioNi0VP1YOhoNh0TP1\OkoNe0TP1\OloNd0TP1\OkoNe0TP1\OloNd0TP1]OkoNc0UP1]OkoNc0UP1]OkoNc0TP1^OkoNc0UP1^OioNc0VP100001O000000O100000000O10000O11O0O2O00001O0000000000000001N1000000000O1000001O0000000000000000000000000O10OO2N2O10O1000000000000O10O100000000000001O00001O00000000O100000O10UOQPOLPP14PPOLPP14PPOLQP13ooNMQP13ooNMRP12noNNRP12noNNRP12noNNSP11moNOSP1k0000VOmoNOSP10ooNOQP11ooN[OO>RP16QPOZON0QP16QPOZON0UP11TPONlo01UPOOko00VPO0jo0OXPO0ho01VPO0jo00VPO0jo00VPO0jo01UPOOko01TPO0lo00loN_O3a0QP10loNA10RP1OloNB2?RP1OloNB2?RP1OloNB2>RP11loNA2>QP12noN_O1?QP12noN^O20PP13UPOMjo04VPOLjo04VPOLjo04VPOLio05ZPOHfo08ZPOHfo08ZPOHfo08ZPOGgo08ZPOHfo08ZPOHfo08[POGeo08\\POHdo08\\POHdo08\\POHdo08\\PO_O@4TP1<]PO@_O4TP1<]PO@_O4TP1<]PO@@3SP1=^PO^O@4SP1>]PO^O@4SP1>]PO^O@4SP1>]PO^O@4SP1>]PO]OB3RP10\PO^OA3RP1?]PO_O_O3TP10ZPOFfo0;YPOEgo0?ooNWOO;QP10moNVO2:QP1f0moN[OSP1e0moN[OSP1f0loNZOTP1f0loNZOUP1d0loN\OTP1d0loN\OTP1d0loN\OTP1d0moNZOTP1e0moN[OSP1d0noN\OSP1c0moNUON1UP1i0ooNTOZP1l0foNSO[P1l0900L40WoNZOP1b0\\oN]O33P1?_oN]O14P1?_oN]O14P1>oN^O05_P1<hoNDWP1=joNAWP1?ioNAWP1?ioNAWP1?joN@VP10koN_OUP10loN@TP10moN_OSP1a0moN_ORP1b0noN^ORP1a0ooN_OQP1a0ooN_OQP1<_oNF0NQP1<oND00PP1<TPODlo0<TPODlo0;UPOEjo0<VPODA0oo0<POD@1QP19POF@0PP12hoN4\\Q1KfnN4ZQ1KhnN3Q1MTYn]1’,
‘size’: [1080, 1920]}}
While running inference via MaskRCNN — TAO Toolkit 3.22.02 documentation, there are output annotated images.
  • -o, --out_image_path : The directory path to output annotated images.
Thanks for the reply. I had already output the annotated images but I needed the isolated segmentation predictions for another piece of the project I am working on.
For anyone else encountering this road block:
The segmentation output is encoded in COCO compressed RLE (Run-length encoding) format (see here: cocoapi/mask.py at master · cocodataset/cocoapi · GitHub).
To go from the encoded string to segmentation contours do the following:
import pycocotools.mask as mask
import json
import cv2
import numpy as np
json_dir = “./JSON-DIR”
f = open(json_dir+’/prediction_json-file.json’,‘r’)
annos = json.load(f)
f.close()
seg_obj = annos[0][‘segmentation’]
mask_obj = mask.decode(seg_obj)
def polygonFromMask(maskedArr):
# adapted from https://github.com/hazirbas/coco-json-converter/blob/master/generate_coco_json.py
contours, _ = cv2.findContours(maskedArr, cv2.RETR_TREE, cv2.CHAIN_APPROX_SIMPLE)
segmentation = [ ]
valid_poly = 0
for contour in contours:
#Valid polygons have >= 6 coordinates (3 points)’
if contour.size >= 6:
segmentation.append(contour.astype(float).flatten().tolist())
valid_poly += 1
if valid_poly == 0:
raise ValueError
return segmentation
poly_obj = polygonFromMask(mask_obj)
This will result in potentially several polygons per prediction so make sure to use all of them to match the original model output
Hope this will help someone!
